Mk6 r steering wheel
Ryzar1
Post by Ryzar1 »
Hey guys I've just replaced my mk5 GTI wheel with a mk6 r wheel got everything working except the horn I've triple checked everything I've even updated the slip ring still won't work any help would be appreciated cheers
Sent from my Pixel 7 Pro using Tapatalk
Re: Mk6 r steering wheel
There must be some faulty part in the loop if you've checked everything.
The mk6 steering wheel has the internal control module in a position where it can get water damaged if it's been sat in a breakers yard open to the elements.
allanwarnock
Post by allanwarnock »
100% sure you attached all spade connectors?
Ryzar1
Post by Ryzar1 »
Yes everything is attached as it should be the mk5 one still works when I switch them out not getting any other errors either
Have you set the coding correctly for the change from Mk5 (LIN1.3) to mk6(LIN2.0)?
Ryzar1
Post by Ryzar1 »
I've only done the coding for the control module
It's been a while since I did this type of coding but I seem to recall there's some numbers 1-4 for LIN1.3 and 4-7 for LIN2.0
You need LIN2.0 for a mk6 wheel so this will need to be changed when swapping from mk5 between mk6 wheels.
