Hi guys,
I usually carry heavy loads and when loaded the back is way too low. Any recommendations on what I can do. Heavy duty suspension or a helper kit?
Leaf springs
- Azz03
Re: Leaf springs
[mention]Servicon [/mention] that’s what I’m looking at going for the heavy duty leaf springs that come on the British Gas vans
Re: Leaf springs
SWB Heavy Duty
https://www.eurocarparts.com/p/sachs-le ... -667440310
Maxi Heavy Duty
https://www.eurocarparts.com/p/sachs-le ... -667440300
Be careful going off details for ex BG vans as the SWB and Maxi use different length springs.
Maxi Heavy Duty
Re: Leaf springs
Thanks gents
- Azz03
Re: Leaf springs
Cheers [mention]Doc [/mention] always nice to know someone who has the info to make things easier. Didn’t know euros did them. I’ve found another brand called kilen part number comes up as 2k3511151t think I got them down to £117 each which isn’t bad.
Re: Leaf springs
With the current discount code, let's face it there will be another along in a week, at ECP, they are £191 for the pair of SWB HD leafs.
- Azz03
Re: Leaf springs
[mention]Doc [/mention] thanks mate will have a look on there and get a set ordered.
Re: Leaf springs
Sorry to revive an old thread but what Leafs did you end up getting Azz as i have the exact same bouncing issue and being a spark/IT Tech with the van constantly loaded and lowered is driving me insane!
Mine is a SWB 55 plate so it should be the identical leafs as you got.
55 Caddy 1.9tdi ASZ - Refrofitted Cruse, Projectors, HID, Auto Wipers, Auto Lights, Footwell Lights, Highline Display, MFSW, AL Injectors, GTB1752 turbo and 02Q 6 Speed.
- Azz03
Re: Leaf springs
[mention]gavzzorz [/mention] sorry mate I haven’t been on here in a while, you’ve probably already sorted it by now on you’re van, but I went with the heavy duty leafs for the swb and it changed the whole feel of the rear end big time no more bouncing all over the road even with the slightest bump in the round. I also fitted some gaz short adjustable shocks and also made it a lot better. I’ve been looking at upgrading the shocks to some bilstein ones.
