BKD Converted Caddy - Why are my brake lights staying on ?
D1cky
Post by D1cky »
Hopefully someone can assist me with the following fault codes.
My 2007 Caddy (originally a 2.0 SDI), it recently had a 2.0 TDI BKD engine fitted out of a 2004 Golf GT TDI.
The van/engine runs fine and boosts as it should.
The glowplug light constantly flashes.
And it has the stored faults below.
●Brake Lights
DTC Code: P0571
The brake lights stay on when ignition turned on, they illuminate without the brake pedal being depressed.
The brake light switch has been replaced for a new Febi one.
All feeds/wires to the brake light switch have been tested and they are fine.
They have 12v feeds where they should and the ground terminal has good continuity.
●Fuel Pump
DTC Code: P1541
It will not prime/run when the ignition is turned on.
The fuel pump will prime/run when a jumper wire that provides 12v power is connected to Fuel Pump Relay Terminal 2 (87).
All feeds/wires (1-->5) (30-85-86-87) to the fuel pump relay have been tested and they are fine.
Could this be due to fusebox/glowplug wires being connected incorrectly ?
The Fuel Pump Relay has me stumped as I've tried new relays with no success.
Sent from my SM-S918B using Tapatalk
D1cky
Re: BKD Converted Caddy - Why are my brake lights staying on ?
Post by D1cky »
Fuel Pump issue resolved. Dodgy connection.
The brake light and flashing glowplug light continues.
There may be a problem with the power to the brake pedal switch. If I remember correctly, the lights stay on constantly when the switch circuit fuse blows, it's a fail safe feature.
D1cky
Post by D1cky »
Doc wrote:There may be a problem with the power to the brake pedal switch. If I remember correctly, the lights stay on constantly when the switch circuit fuse blows, it's a fail safe feature.
The fuse is fine. Strange.
I checked it. I was hoping it was that for an easy fix Image
Have you checked for power at the brake pedal switch?
D1cky
Post by D1cky »
Doc wrote:Have you checked for power at the brake pedal switch?
All good.
I have power.
I checked wires K65, K87 to the ecu from the brake switch electrical connector for continuity.
Checked the brown one too.
D1cky
Post by D1cky »
D1cky
Post by D1cky »
D1cky wrote: Thu May 02, 2024 9:12 pm All good.
I have power.
Although no mention of a brown wire on the wiring diagrams. Odd...
https://youtu.be/LF7FjtSNmRU?si=qTh_5RsqszcCJ_Dm
