Hi stan,stan-the-man wrote:The top panel looks like proper caddy one as it doesn't have heated rear screen
The lower is AC which is no good.
thanks alot for the info, i got the seats today, they look great, will have a go tomorrow at fitting them, I ordered 2 modules for the heated function but having seen your note on numbers, I may well need to get some off you as they may be wrong. Will i need 2 or just 1 to work both seats?
So, to recap, I have the bog standard 2011 caddy, no a/c. The heater control units with a/c function on them won't work but ones without a/c function will, like this one, is that right?
Also the looms you make, if coupled with the modules, would they supply everything to the seats, i.e. powered movement, lumbar and heat?
Finally, do you need to see the back of the above unit, might be able to get a pic sent?
