Armrest
- Stuart123456789
Armrest
Good evening I have a 2016 caddy and want a centre armrest the after market ones which I’ve had in previous caddy’s don’t apparently fit any suggestions ?
Armrest
Would a centre console from a 2016 touran not fit as they do ok the older caddy’s?
Re: Armrest
2016 Touran is the 5T model which has a totally different interior.
The 2003-2015 Touran armrest centre console fits the Caddy4 but the plastics on the older ones is a lighter colour.
- Liam
Re: Armrest
could you cut the touran console close to the arm rest and attach it to the caddy mk4 console ? so that the joint is hidden by the seats?
Build thread here
Build thread here
Re: Armrest
Ahh ok Doc, just a thought.
- Stuart123456789
Re: Armrest
I appreciate your comments not sure I’m any the wiser tho maybe vw can help I’m booked in at the Van centre anyway for the infamous whistling wing mirror which I’ve been told is really a characteristic of the caddy van
- Liam
Re: Armrest
hey stuart the whistling mirror is fixeable
Build thread here
Build thread here
- Primal730
Re: Armrest
Just bought a touran center console with armrest of fleebay... will post pics of install...
Nothing ever just fits!!!
Porsche wheels is prime example
11 plate caddy
Lowered
Porsche 18’s
Golf gti seats
More to come
Lowered
Porsche 18’s
Golf gti seats
More to come
Re: Armrest
Check the how to guide on here mate. It’s spot on for fitting the console
- Stuart123456789
Re: Armrest
Thanks I’ll take a look. As regards mirror I’ve read the noise will stop if I use tape or sealant behind and round the cover. Van is still under warranty and surely if it’s a known fault vw should rectify it ? Joking aside it’s unbearable at motorway speeds
- Primal730
Re: Armrest
Thanks matethe swan fiend wrote:Check the how to guide on here mate. It’s spot on for fitting the console
Just waiting for enough posts to be able to view the info I need!!
11 plate caddy
Lowered
Porsche 18’s
Golf gti seats
More to come
Lowered
Porsche 18’s
Golf gti seats
More to come
Re: Armrest
How ? It’s soo annoying lol
Remapped
Side rail cover
18” Audi alloys
Facelift seats
Tinted windows
And much more too add soon
Side rail cover
18” Audi alloys
Facelift seats
Tinted windows
- Liam
Re: Armrest
its the gap between the front and back halves of the mirror between the mirror and the door so the gap between the door and the mirror at the joint if you cover the gap with tape and go for a drive you will see what the problem is i ended up sealing it with sealant to seal the gap and prevent the whistle
Build thread here
Build thread here
Armrest
There is a how to on this site. It’s the best mod I’ve done so far. Was so annoying and an easy fix.
I used a thin piece of double sided foam backing tape. If you have something similar like gasket tape or even a foam draught excluder cut to the right size will do the job.
- Liam
Re: Armrest
had this same issue and tried the felt in the gap and it didnt cure it to my total frustration but i kept putting electrical tape on and taking it for a drive until it stopped
i eneded up using black sealant arount the gap between the mirror and the front plastic trim and its now cured the whistle
see pics
taped this piece up as i was still getting a whistle
taped this bit and the whistle stopped so this was the problem on my mirror not the lower piece
ran some black sealant around it and havent had a whistle since
see pics
Build thread here
Build thread here
