Could I run 19s with a coilovers kit
As it says in the title just been offered a set of 19s at a good price but not to sure if I can run them with the coilovers I want, any advice will be well received.
Re: Could I run 19s with a coilovers kit
Actual wheel size is 19 5x112 10 j if this helps will try posting a picture as well
These are the wheels
Sent from my POT-LX1 using Tapatalk
- Caddyluv
10j you won’t be able to open the side door.
Cheers caddyluv back to the drawing board then, what's maximum size so you can still use side door ??
Probably 10" wide maximum if the offset it bang on.
Cheers Doc I suppose the only way to find out is to try different wheels
If you have a ruler, you could measure your current wheels are work it out from there. It's simple maths.
There's even a website that does all the calculations for you!
Thanks Doc IL give that a go tomorrow
