Barn door problem
Grantek
Barn door problem
Post by Grantek » Wed Dec 18, 2019 8:16 pm
Hello all. Have a problem with my Caddy 4 that my barn doors are showing as open when they are closed. Seen problem about side door sensor on the forum - not sure it’s this.
Side door is showing ok on dash. Showing open when open and showing closed when closed.
Just back doors that are playing up. The van still locks but lights remain on.
Any help would be great, thanks
Giddy
Re: Barn door problem
Post by Giddy » Wed Dec 18, 2019 8:24 pm
Instagram: @giddywagen
Post by Doc » Wed Dec 18, 2019 8:25 pm
A few people have had problems with rear doors recently, seems the lower latch gets moisture in and then the switch fails.
Grantek
Post by Grantek » Wed Dec 18, 2019 8:26 pm
Can’t view that yet. Put my request in recently for my post count 👍
Grantek
Post by Grantek » Wed Dec 18, 2019 8:27 pm
Any idea of a part number for switch? Also do you know what door it’s in? Thanks
Post by Doc » Wed Dec 18, 2019 8:29 pm
It's in the big door, the switch is part of the latch, I don't think it's available separately.
You can just unplug it and it'll show as shut full time.
Giddy
Post by Giddy » Wed Dec 18, 2019 8:48 pm
If you want to have it working as it should, then there are two part numbers for the Caddy 4 bottom latch. 2K0827505J 9B9 and 2K0827505L 9B9, I think the difference is in the connector shape, but might be more than that. Pop over to your local VW and they will know which one you need by your VIN. They are not expensive, in region of £20-25.
Grantek
Post by Grantek » Wed Dec 18, 2019 8:54 pm
Got it sorted guys. Took Doc’s advice of moisture and used some tetra action blaster to disperse anything lurking in the catch. Back to working order. Thanks again 👍
