So today I finished off installing the 2 x new injectors.
The van seems to run fine but the engine management light is on. The injectors haven't been coded yet - Does thie coding need to be done PDQ??? The codes weren't sent with the injectors...Is this all done through VCDS?
I did replace the return pipe from all injectors due to one end breaking in the injector...PitA!
Prior to swapping the injectors the glowplug light came on after about 2mins and it started running rough. No other lights on.
Amber engine light after 2x Injectors renewed
