Arm rest installation
Hey guys got a hold of a proper arm rest going to
Try my luck installing it I got the special bolts and all the screws that came with just had a few questions first one is trimming of the rear is that necessary if you don’t have a bulk head I still have the bar from the raised floor though also I have glued a leather gaitor on the handbrake do I have to remove that to unscrew the casing or can that be left on any advice would be appreciated cheers.
- Giddy
Re: Arm rest installation
Yes, you have to cut it, it's the floor piece that gets in a way.
You don't have to do anything to a handbrake other than detach the cables.
It's all pretty obvious and straight forward, once you start doing it
Sent from my Pixel 4 using Tapatalk
Could I cut a large notch in the floor bar instead I don’t
Like the idea on trimming the arm rest
- Giddy
Armrest cost nothing in comparison to rebuilding the floor, in case you need to. But it's up to you, you can cut the floor if that's what you want to do. I've seen somebody has done that before.
If you plan on fitting rear seats in the future then cut the floor....
Cut two slots and bend the lip down that way you can bend it back and weld it back up if you ever need to can't do that if you trim the plastic .
Arm rest installation begins
Cleaned the whole front end removed seats and touran bases cleaned the new arm rest console
Just cut all the rubber and set handbrake all the way up
I didn’t want to cut the arm rest console so I’m hoping this will work instead
Putting the seats back in now arm rest finished
Thats looking well mate.
Cheers I ended up cleaning the back bar I cut i notch in everything fits nice and secure I would like to get the armrest cig lighter working for an extra plug but that will have to wait a bit got a new brake kit coming and some engine parts to concentrate on
Love this.
Plus you have the DSG which I do.
Regarding the armrest parts, are they just the same for a manual gearbox as a DSG gearbox? All the ones on eBay don’t specifically say so I don’t want to end up buying one that won’t hold a DSG
Advise welcome!
Plus is there anybody in Manchester that could do this thanks
Advise welcome!
I’m pretty sure it doesn’t make a difference between dsg and manual I’ve since then done a rear seat conversion
Since getting the van I've been crying out for an armrest.
Do you know the part numbers involved or this come from a donor car ? Touran?
Sorry if I'm lagging behind here, I've not seen anyone retrofit the centre console like that before.
I was considering buying one of those cheap jobs, kind of like this...
Amazon Uk - Search : AB1 flexzon Black Pu Leather Armrest Center Console
Would love to do something like your job.
