Some more progress on the Caddy mainly around the left hand rear wheel arch. In keeping with the idea of reusing as much of the old steel racking as possible I decided to make up a steel frame the same height as the slide out bed but face it with aluminium chequer plate as it will act as a kickboard when sat on the sofa/bed and I'm probably going to put bikes etc down that side of the van so I wanted something robust. I insulated the wheel arch with one layer of the self adhesive foam and then used shiny bubble insulation once the frame was in place.
The top of the wheelarch is covered with 10mm ply held on with self drilling flat head screws so is easily removable as is the chequer plate which uses the same screws and some of the threaded inserts in the racking. Above the wheel arch is the start of the ply panelling and then a small shelf to hold mugs of tea in the morning - I hope!
I quite like the look of the steel and aluminium and leaving the fixings on display, not everyones taste I'm sure but robust and practical. There will be carpet higher up and on the floor I'm using carpet tiles as they stay in place but are easy to take out and clean/replace if needed. I've also cut down the stainless steel sill that came with the van with a thin metal cutting blade in the angle grinder which you can see in the left hand photo.
At the front of the wheel arch rather than waste the space I made a couple of little shelves and a cover for the seat belt mechanism. You can't get much in them to be honest but it was only bits of scrap ply and a couple of hours time so not a big investment and will hold a headtorch, batteries etc so will be useful.
The seat belt mech cover was a bit tricky as it had to be big enough to cover the mechanism but not foul the seat backrest. It's easy to get caught out when you're fitting out the van remembering that if you alter one thing it may have a knock on effect on something else..
Next job is to decide what to do with the space above the left hand wheel arch, easiest option is to carpet it all but maybe a small flat screen...?
