2011 caddy central locking rear doors not working
Eye'd a nice Caddy?
Maybe a member off the forum
What, Where, When in title please.
K.boyce
Post by K.boyce »
Hi guys
New to the site. Iv got a 2011 VW caddy the central locking is
Not working on the sliding door and the rear door. The light
In the back is on when the doors are shut. Looked at door rear catch found plug a bit green cleaned up but still same.
Looked at the central locking with scanner found
2 codes
02483 module for locking of rear lid (F327) not a plausible signal
03396 supply voltage terminal 30 for central locking open circuit
I have no power to side door or rear door.
ofkys71
Re: 2011 caddy central locking rear doors not working
Post by ofkys71 »
Hello there.
I just joined the forum.
I had the problem you mentioned.
Maybe this message may not be published because my post count has not been completed yet.
Oxidized areas may be interrupting communication. I think your problem will be solved if you clean these oxides and lift the nails a little.
Good forums.
ARSHAADJ
Post by ARSHAADJ »
Thanks a lot, i had similar issue!
