What an awesome feature on your awesome caddy in performance VW magazine. Just shows you how good this build really is
Toffee delights
- Sean1066
Re: Toffee delights
Well done Chris.
- Lister79
Re: Toffee delights
Thanks very much for the compliment Sean
.Sent from my iPhone using Tapatalk
nigey48
Re: Toffee delights
Hi pal did you fit a reversing camera
- Lister79
Re: Toffee delights
Hi, yeah I have recently fit one. If you have a look on page 102 the details are on there.
nigey48
Re: Toffee delights
I'm new to this forum thing .do you have any links for the items I need to do this I've got a mib 2 std/nav unit inthe caddy cheers
- Lister79
Re: Toffee delights
Hi, the links for the items I’ve used are in the post about it.
My headunit is an RNS510 so different to yours. I could be wrong but I believe yours shouldn’t need the additional module, and should just need a camera and possibly adapter cable for in the radio connector. Have you looked in the technical section? as I’m pretty sure there will be info in there about it.
nigey48
Re: Toffee delights
Hi pal I've tried in the technical section but says not got permission
- Lister79
Re: Toffee delights
You need to request an upgrade in the appropriate section (as stated on your sign up email.
- Lister79
Re: Toffee delights
Gave the van an oil and filter change today; and installed the pointless but totally essential Christmas presents off the wife, Racingline Oil filter housing and Magnetic sump plug. Question is do I also now need the Racingline rocker cover cap? I like the original with the Castrol branding and yellow detail but thinking it looks lost now.
Also made a Racingline grill badge using some Carbon fibre plate and angled ABS. I’m not 100% sure about it, so it may get removed yet.
Shiny stuff
Installed (I did say pointless, but essential)
Swapping the housing internals
Before
Badge installed
Badge in work
Shiny stuff
Before
Badge installed
Badge in work
- J_Con
Re: Toffee delights
I quite like the badge
something a bit different!
something a bit different!Sent from my Pixel 6 Pro using Tapatalk
- Chris_Fz
Re: Toffee delights
Looking mint bud.
-Vw Caddy Pv 2.0TDI 2015 stage 2 + 110wkw / 376nm -
-Nardo Grey & Black Trim
-Rolling on 19" A-line Hostiles
-Owner of Retrofitters
-+2771 027 5064-
-+2771 027 5064-
- Lister79
Re: Toffee delights
Thanks both.
- Lister79
Toffee delights
It’s always nice to come home to a parcel delivery
I’ve been having the bulkhead side plates for in the engine bay, and the rear light cluster trims Carbon Fibre skinned.
It’s the little things.
Bulkhead side plates
Rear Light cluster trims
Re: Toffee delights
Gotta love all these little details that will go unnoticed by many.
TMB7XHR
Re: Toffee delights
Very nice, all the little things add up!
