- skidmark
£95 ebay Audi A3 wheels fitted, included 3 good bridgestones too
2018 Trendline 1.0 Petrol
mkvanman
Thats the way to go.
Yardstick
Caddyshack57
I might cover them myself fella ,,, not sure yet
- Convw
Roof wrapped. H&R springs fitted.
- paul4314
That looks awesome roof goes really well with the green
Caddyshack57
mkvanman
Convw love the look of your van there is a similar in Milton Keynes with a large VW on the sides.
Chrisg1980
ConVW that looks mega pal
are you gonna get a side rail cover?? I just got one from Reflex and it makes such a difference.
Chris
Chris
2007 1.9tdi, Mk5 GTi front seats, Touran front end, Removed Bulkhead, Sound deadened, insulated, Carpet lined, VMaxx coilovers, colour coded rear bumper, Touran front carpets, 3SDM 0.04's, Alpine 136BT, Touran centre console w/armrest, MK6 GTD flat bottom steering wheel, Reflex Caddy Siderail cover, German Driverside(UK Passenger side) wingmirror...
Still to come - Focal speakers
- Cookie4086
Got the Roof Vent painted silver and fitted for the Dog, not wired up yet though, but got the split charge system on order so I can have it run the roof fan and the animalarm (automatically texts me when the temperature gets over a pre set limit) without worrying about running the battery down.
Cookie.
Geraout
Upgraded fog lamp bulbs to Osram Night Breakers....
I noticed that the cornering function was not working so I hooked up my VCDS and recoded so that fog lamps come on on the turning side (indicator or steering wheel turn) and both fogs come on when selecting reverse gear.
I was surprised that they were not doing that as standard; being as it is specifically mentioned in the Caddy brochure.
- biggeodan
can you share some pics of your seat belt positions in back PLS un sure where to weld mineilz2729 wrote:Fitted rear touran seats and rear carpet. Re carpeted the lot and modified everything to suit...
Starting to take shape
- ilz2729
I used the lower holes. Cut out a bit so the plates with the nut welded on would fit in then welded around it. It's solid. Then the floor ones by the sides of the seats were welded to the floor and a shorter bolt was used. Lap belt for the middle was bolted on. Pm me if you need any further help. I can take pics to help and send them to you if need be.
Yardstick
Nice arm rest... Is that the one that basically goes into the cup holders?
Tidy job with the seats
- Convw
Yeah. Just haven't ordered one yet. Holding off as I may change mirrors and want to get all the colour coding done at once.Chrisg1980 wrote:ConVW that looks mega pal![]()
Chris
