Yeah, works as good as it look. Couldn't deside where I wanted to mount the bar, so I mounted over licenseplate now and made longer cables so I can unplug and move the bar under the grill.mgdenison wrote:
Easy fit. Hardest part is to get a cable from the realy in enginebay and into the car. Or you can do it easy and take a cable from headlight if you don't want a switch inside to be able to turn of the bar and only use highbeam on headlight.
