My Mountain Biking Camper Caddy build
aerobic247
Re: My Mountain Biking Camper Caddy build
Post by aerobic247 »
shanky887614 wrote: put kingapan in, that stuff is awsome.
technically it wont make it warmer but it will take it longer toto heat up and cooldown naturally inside (using aircon/heater will be more effective)
i use Kingspan at work, it is ok but it would leave to many cold spots
shanky887614
Post by shanky887614 »
i was thinking more of the rolls like what they put on ducting than the foam sheets
kingspan is just the brand and they sell many different types on insulation
imray
Post by imray »
Smart van Mr aerobic , was wondering how you fixed the axle mount to the ply ? Thanks
aerobic247
imray wrote:Smart van Mr aerobic , was wondering how you fixed the axle mount to the ply ? Thanks
i used Tee nuts http://www.screwfix.com/p/easyfix-4-pro ... f-10/79359
aerobic247
shanky887614 wrote:i was thinking more of the rolls like what they put on ducting than the foam sheets
yeah i know what you meant, if i was insulating a T5 with big flat surfaces i would probably use that but the Caddy has too many contours
imray
Post by imray »
the mounts would be removable then by undoing the bolts from the top I take it , thanks
Nickrexx
Post by Nickrexx »
Loving the bike mount . I'm getting myself a couple of them. Bye bye bungee clips. :)
beasty7j
Post by beasty7j »
Nice work I'm doing the same thing I'm looking at the battery's at the moment did you just put it behind the driver seat was it easy to get a cable from main battery to there?
aerobic247
No put it behind the passengers seat as it's closer to the starter battery and on that side there is a hole to feed the cable through
northern8019
Post by northern8019 »
aerobic247 wrote:i got them from here http://www.bambuzo.com/uk/rockymounts-d ... ft-sd.html
Awesome mounts aren't they, spares having different individual ones
Great build thread too mate
1.9tdi / Calibre CR3 / Lowered-Axle Flip / RNS510 / GTD Seats / Touran Rear Setup
6sp / Touran Bumper / Fogs / Highline Dash / CC / MFSW / Touran Leather Centre Console / now in the 200+bhp club
SimonR
Post by SimonR »
That does look very cool and nice and warm
Burrows750
Post by Burrows750 »
Any plans to build bed or is it purely a day van? Do you have a link to the insulation you used? I've used eco wool before but it's a bugger for holding moisture.
aerobic247
Burrows750 wrote:Any plans to build bed or is it purely a day van? Do you have a link to the insulation you used? I've used eco wool before but it's a bugger for holding moisture.
i plan on adding a bed, just not had the time to do it here is the link for the insulation http://www.diy.com/departments/diall-lo ... 658_BQ.prd" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
jackel
Post by jackel »
Thankyou ordered :)
sco116
Post by sco116 »
nice build bud.
just picked up my new van and have been thinking about using the same bike mounting system.
I thave found these which looks a cheaper alternative. ( 20mm are avalible as well)
http://www.wiggle.co.uk/sea-sucker-15mm ... ugh-axles/" onclick="window.open(this.href);return false;
