Side rail cover
owen12345
Side rail cover
Anyone know the best/cheapest place to get just the cover from. Don't a guy on here do them ? Thanks
Lembot85
Re: Side rail cover
I'm in the same boat mate I'm not paying over £100 for one
- Ash08
Re: Side rail cover
TPS will be your cheapest option then depending on your skillset paint and fit yourself.
chris855
Re: Side rail cover
Do you know the part number for TPS? Tried a search and can't find it.Ash08 wrote:TPS will be your cheapest option then depending on your skillset paint and fit yourself.
- tonyhill
Re: Side rail cover
Is there a "how to" on fitting these rail covers? Are they simply bolt on, or is there more involved??
- turbodcaddy
Re: Side rail cover
There's a little to it you'll need to make a bracket that sits inside of the sliding door so it can be secured and the back is just a push clip you can use the clip that you take off the plastic piece if you still have it I do have a template for this bracket
Caddy turbo for sale!!!!!!!!!
- Decinick
Re: Side rail cover
You don't always need to make the bracket, usually 09 plate onwards already have them, Reflex Auto Design sell a bracket that is made for it if you can't make one.
As already stated TPS or VW for the cover, part number is in the useful part numbers thread, about £35 I think.
- tonyhill
Re: Side rail cover
Do you have to change the rail aswell..? Only reason I ask is because on RAD's website it lists the package as 'rail, cover and bracket'.
rftrft
Re: Side rail cover
I don't think you have to change the rail, I hope not as I am hoping to fit one soon as I think these look so much better. Mine is a 2010 pre face lift so I am hoping it comes with bracket.
- Barbel330
Re: Side rail cover
The reason people change the rails is because they have clips on them for the cover to clip to, your original won't. I've seen people on here say that they've put a blob of adhesive on the rails instead but I've no experience of that. I don't think the rails are too much money to buy?
Instagram: @y_5cuf
- Ash08
Re: Side rail cover
i cut and bent some steel (around 2-3mm thick) you need to bend it into a L - V Shape then i used the original back clip and a blob of adhesive, took me about an hour to perfect it but saved me monies
i bought my rail from the local VW dealer
, think it was £43
2K0843795B Left Rail Cover
2K0843796B Right Rail Cover
7H0843658A Clip For back End of Rail
Lembot85
Re: Side rail cover
Cheers mate think I'll give that a go!
chris855
Re: Side rail cover
Just what i wanted to know. Cheers
harrycrumb
Re: Side rail cover
Ash08 wrote:i cut and bent some steel (around 2-3mm thick) you need to bend it into a L - V Shape then i used the original back clip and a blob of adhesive, took me about an hour to perfect it but saved me moniesi bought my rail from the local VW dealer
, think it was £43
Perfect, this is going to be my 1st external mod, then onto the handles, and I have a TPS up the road from my work too
- Poffe
Re: Side rail cover
Is it the same numbers for Side rail covers to a Maxi?
