Maxi life build
- LeeH
Re: Maxi life build
Hull area?
Sent from my iPad using Tapatalk Pro
2011 2.0 GT Bluemotion Tech DSG in Candy White
2012 1.6 Highline Bluemotion Tech Caddy in Indium Grey
- torque777
Re: Maxi life build
Sowebry bridge business park unit 4
- torque777
Re: Maxi life build
Ok so not posted in a while.. Nothing much happened and no money spent on the caddy yay!!.. But my rear brake light has exploded over night, had to super glue it back together and do a temporary fix for now, new one on order.
- torque777
Re: Maxi life build
Another breakage is the gas ram off the single rear seat, the ball snapped off out the seat so will need to drill the seat out and re tap, new one is only £3 from tps if I can get round to do it
- torque777
Re: Maxi life build
So mot time and number plate lights have died... Spent ages trying to get them to work but the terminals are broken, so decided to hard wire them..
- torque777
Re: Maxi life build
Fixed the gas ram on the rear seat
- torque777
Re: Maxi life build
Passed mot but had advisory on front tyres, only done 10k but down to 3mm and side wall worn
- torque777
Re: Maxi life build
Also fixed rear brake light
- torque777
Re: Maxi life build
But the seal is too thick
Re: Maxi life build
That’s a lot of side wall wear for a 10k old tyre? I’ve seen a few caddy’s now with exploded 3rd brake light? What do you think caused it? Ice?
- torque777
Re: Maxi life build
Yes the seal started to come out the side, and water got in and I think it froze then and became brittle, the tyre side wall has wear because I constantly go over speed humps and they rub the side walls
Re: Maxi life build
Wow, that's crazy wear for speed bumps, I'd bring it up with your local council if your having to replace all 4 tyres too often because of their speed bumps.
Re: Maxi life build
Was that wear only on one side or on both inner and outer edges.torque777 wrote:Yes the seal started to come out the side, and water got in and I think it froze then and became brittle, the tyre side wall has wear because I constantly go over speed humps and they rub the side walls
Re: Maxi life build
Hi great van. A good read.torque777 wrote:Also de badged rear and modded mirrors to stop whistle
What’s the wing mirror mod?? The whistle is driving me crazy. Got some wind deflectors thought would stop it but doesn’t.
- Afield23
Re: Maxi life build
I just put a thin layer of foam tape in between the mirror and the base, that's where the whistling comes from. I believe there is a how to on it somewhere
Sent from my SM-G928F using Tapatalk
