My Blackberry Caddy
- Barbel330
Re: My Blackberry Caddy
EMtuning will build you lights to whatever spec you want or whatever your budget is. Mine are Morimoto bi-xenon projectors so the light output is phenomenal compared to standard halogen and even factory bi-xenon. The colour change angel eyes and demon eyes are just a fun add on which I can control via a phone app.
Instagram: @y_5cuf
- Barbel330
- Barbel330
Bought some new detailing products recently so as it wasn’t raining, snowing or blowing a hurricane for once I decided to give it its first wash since November.
My favourite new detailing product is a Di Vessel which filters all the dissolved solids from the hard water which I have in my area. The benefit of this filter is that I can now blast it with a coating of Bilt Hamber snow foam, let it dwell on the panel for a few minutes so it drags all the filth off the panel, then just rinse it off with Di water and walk away. No more water marks
Zero contact wash so no dragging winter grit and grime all over the panels.
Instagram: @y_5cuf
- Afield23
That's impressive- where did you get it from?Barbel330 wrote:Bought some new detailing products recently so as it wasn’t raining, snowing or blowing a hurricane for once I decided to give it its first wash since November.
My favourite new detailing product is a Di Vessel which filters all the dissolved solids from the hard water which I have in my area. The benefit of this filter is that I can now blast it with a coating of Bilt Hamber snow foam, let it dwell on the panel for a few minutes so it drags all the filth off the panel, then just rinse it off with Di water and walk away. No more water marksZero contact wash so no dragging winter grit and grime all over the panels.
Sent from my SM-G928F using Tapatalk
- Barbel330
- PaulC61
After washing do you use a blower to blow the water off the Caddy? Even gently towelling off the water I end up with some sort of residual water mark on the paint.
- Barbel330
I've never used a blower actually but I reckon it'd take quite a while to dry a van with one. My van has a compressor built into it for work and I've occasionally used the airline to blow out grills, mirrors and badges. All those areas that tend to drip for hours
With this filter though I don't need to dry the van at all now, literally final rinse down with Di water from an open hose to sheet the majority off the panels, then walk away. It can drip dry without water marks. I tested my tap water with a tds meter and it was 420, then tested the water coming out of the filter and it was 0.00
You could use a quick detailing spray as a drying aid to avoid marks. Just spray it on a wet panel then dry with the towel. Alternatively, go over the van after a wash, spay on quick detailer and buff off. Bouncers Done and Dusted is the best QD, love that stuff.
Instagram: @y_5cuf
- Caddyluv
My Blackberry Caddy
Dude I hope you pay as much attention to detail on the misses.
I do love this van so much.
I do love this van so much. Sent from my iPhone using Tapatalk
- Barbel330
- Barbel330
Today I fitted my R32 rear calipers along with Tarox discs and pads. Also chucked the front Tarox discs and pads on my existing R32 calipers. You might notice that the fronts and rears are now different colours but there is a good reason for that
Old standard little solid discs
New bigger vented ones
Fronts
Fronts
Instagram: @y_5cuf
- ed1119
- Barbel330
My Blackberry Caddy
Before and after of the R32 rears
Bit of beading
Bit of beading
Instagram: @y_5cuf
Savgav
Van looks amazing
Caddyjedi
hello mate i am new to this forum and haven't learnt how to use it yet but needed your knowledge on how to install my mk7 gtd seats similar to seats you have fitted to hour caddy it would be appreciated if you can help please.
the long one
Were they easy to fit (310mm) ?
What’s the reason behind the odd colours ?
