Caddy mk4 build
- Michele
Re: Caddy mk4 build
Did’t had the time today
- r1lea
Re: Caddy mk4 build
You must have the patients of a saint
I’m terrible !
I’ve got to do everything instantly
I’m terrible !
- Giddy
Re: Caddy mk4 build
@r1lea is that 35w bulbs that you fitted with these headlights?
- Michele
Re: Caddy mk4 build
R1lea
- r1lea
Re: Caddy mk4 build
Giddy, yes I’ve fitted 35w d3s bulbs and 35w ballasts
- Michele
Re: Caddy mk4 build
R1lea still no luck with coding them
- r1lea
Re: Caddy mk4 build
So have tried the coding above
- Michele
Re: Caddy mk4 build
Yes i used these codes
Re: Caddy mk4 build
Michele this is I believe LHD caddy alltrack bcm long coding
You can try it if you wish and see if that helps
To my knowledge all caddy 4 alltracks come with xenons from factory so
611A0A3A8025086D088800809000096C03850008424DAD20E48487000041
- Sean1066
Re: Caddy mk4 build
I love your new lights Michele they look awesome.
I think I will have to upgrade to them
- Michele
Re: Caddy mk4 build
Stan the man thanks ! Buth already try it @ work form a alltrack also no luck
- Michele
Re: Caddy mk4 build
Sean1066 thanks
- r1lea
Re: Caddy mk4 build
So it’s either your bcm or the Led drivers
- Michele
Re: Caddy mk4 build
Yeah i think the drivers foutcode led drivers short to plus
- Michele
Re: Caddy mk4 build
