Caddy R360 build thread
- dan@biali
Re: Caddy R360 build thread
The 3d printed parts have turned up. Think they will work. Just gluing the ‘fir trees’ to them so I can work out where the holes need to be and do some sanding where they are joined before gluing the mesh to the back. Still unsure as to colour or finish for them.
They are just leaning against the panel here, they will fit with a gap between the top and bottom.
- BradleyB
Looks amazing dan
- brooneye
You’ve got some vision Dan, would I be right in assuming they will be similar to the lower ones in that picture?
- dan@biali
They have been modelled to mimic the floor but these will be functional as I need the vents to work so the tailgate closes without having to open both doors!
This is with the mesh and the fir trees. Mesh will be installed after they are painted.
- dan@biali
Amazing weekend culminating with another trophy at Trax Donington whilst on the PVW stand and a chance to be a starstruck fan meeting the editor Elliott. Doc very kindly took a few photos and I had to give a very awkward on microphone interview which mercifully was very short and no one was watching! Also met ma photography who I already follow on Instagram and he managed to snap a few photos. Will see what he does with them as there was talk of offering them to a magazine he occasionally works with.
Another well deserved trophy Dan, thanks for inviting me along yesterday was a great day and I got to top up my tan unknown to me until I got home...
- dan@biali
I had put factor 50 on in the morning and had thought it was a bit daft as it was spitting with rain.............burnt face this morning
- BradleyB
Dan the van looks amazing
Well deserved trophy
- dan@biali
Little more work on the coolant bottle cover prototype. Think the plan is to redirect the filter outlet on the catch can as the fumes end up inside the cabin and it stinks of fuel which will mean closing the hole in the cover where it came out. Might leave the area flat in case it turns out I can make it a production piece and people could modify theirs.
looking incredible dude! i have the same tail gate as you what wiper delete did you use?
- dan@biali
Its made by gecleant
Think I’ve sorted a better position for the catch can filter so hopefully this will reduce the fumes in the cabin. I noticed that the barb the filter pushes onto was covered in the oil mist and it was leaking from the bottom of the filter. I’ve instead found the correct sized barb and flipped the hose fitting upside down and run a length of fuel tolerant hose (the black one on the left in the photo) so it now exits at the bottom of the engine bay which should help draw the vapours away. Found a position to cable tie the filter out of the way of anything which means servicing is simple enough too.
- dan@biali
- brooneye
That looks like it’s going to be a great addition.
I struggle with a pencil and paper so hats off to you
- Jeffers76
Credit where its due mate absolutely awesome bud love that
- dan@biali
