- Boonalon
But if you break it down 2 shocks, mounts the kit inc labour aint bad at all
liamcaddy61
When putting on my private reg on earlier I fitted some bright number lights, cant believe how bright they are
Seanick
Shassen wrote: ↑Mon Sep 09, 2019 8:07 am @Seanick
Did you weld on the small studs that the clips are fastened in?
I just got my kit and the clips are a very loose fit on the blades. I can slide them through the attachment points on the blade. Was it the same for you? I went back to the dealer and pointed this out but they said there's no other clips?
No m8...just used very small screws and drilled the cill to attach the clips...but yes I had the same issue...I thought it was the wrong clips but they are perfect when fitted....just dont overtighten the screws as the clip doesn't work properly if you do
Shassen
Thanks for the tip @Seanick.
peely
Is your van a lwb or swb mate
AdoleFiddler
Hiya mate how difficult did you find it? You have any other pictures? Not long started putting silent coat down then I’ve got a thermoliner to go in but not looking forward to it at all
- Giddy
@AdoleFiddler Well... if you want to do it nice, you have to take your time and not rush. There are some more pictures in my build thread. Took me 3 weekends to do all this carpeting. All these corners and curves are quite tricky. It you have ply lined sides it will be much easier.
Seanick
It's a SwB m8peely wrote: Is your van a lwb or swb mate
jackbrehony
As far as I can remember, old seats off bases and new seats in. Changed over seat belt buckles as Audi one was short.
- Golding1994
Well what a night.
Finishing work and the gym to come home try start the speakers and the drill is broke.
So might as well start with the sanding ready for painting Saturday morningm
I officially have 0% patience...
Sent from my H8216 using Tapatalk
peely
I like the look of them seanick but mine’s a maxi so I’m obviously looking for an estate type of blade
Peely, would the a5 sportback blades fit? Might be worth checking
- DeanWhit
Thought I'd take some advice and make some covers out of the bulkhead I took out. Think they'll look decent once they're carpeted.
Seanick
Yea think they are pretty neat m8... on the s5 they don't actually go all the way along the cill...slightly short on both ends so that might have a similar look on a maxi?... get a measure of what you have vs the blade lengths to give you an ideapeely wrote: I like the look of them seanick but mine’s a maxi so I’m obviously looking for an estate type of blade
liamcaddy61
Had some mk4 lights and touran front carpets supplied and fitted at van lab custom conversions in lichfield
Absolutely class service
Only managed to take pictures in the dark which makes the carpet looks tatty but there not. Really happen with the work that was done.
Just need them coding in now.
