broadmoor wrote:Gone yellow lenses , its only vinyl so easy to reverse if i get bored, like the rims its divided opinion , i love a bit of controversy :D
I like it......
Boonalon
Post by Boonalon »
Got a set of wind deflectors fitted today and wired up the loom I got from tommyzoom for the Passat internal light, so all for when it arrives
Josh764
Post by Josh764 »
@broadmoor I'm sure iv said this before, you van looks unreal yellow lenses or not..
Azz03
Post by Azz03 »
James400 where did you get your hoses made mate most of mine are blue on my pd engine. Cheers
broadmoor
Post by broadmoor »
Josh764 wrote: Fri Nov 29, 2019 8:51 pm @broadmoor I'm sure iv said this before, you van looks unreal Image yellow lenses or not..
Thanks so much , it’s pretty much done now.
mikenorman
Post by mikenorman »
Latest project. These were a bit fiddlier to get in and sit right because they’re bulkier. Just spent an hour on a scrap insert to fit one ImageImage
This set is going to be a single halo as a side light that has a switchback indicator in it and I’ll be fitting a projector to the dipped beam. I wanted to sway away from the bigger halos as I’ll be in “copying” territory no doubt at some point so wanted to try something different.
Fingers crossed it works as planned!
Novakid
Post by Novakid »
Everytime u do these Mike they turn out awesome.
mikenorman
Thanks novakid! I take my time on building them to get them to how I want them to look.
DeanWhit
Post by DeanWhit »
A service this morning followed by a couple of hours sound proofing the back.
Need to do the roof and then I can finally get it carpeted. ImageImageImage
Lad.In.A.Cad
Post by Lad.In.A.Cad »
Paid for it
Bring on Tuesday 8)
Josh764
Post by Josh764 »
Sorted wheels and coilovers late yesterday, really pleased with how it's turned out. Managed to squeeze the 9J wheels on with 245/45's. 8mm spacers on the front backs went on without spacers, sliding door is close but opens fully ImageImage
Novakid
Post by Novakid »
That wheels look mint Josh
Josh764
Post by Josh764 »
Thanks buddy, was worried they wouldn't go on,, so glad they have.
Yea I like them, fill the arches up a treat
RKDesigns
Post by RKDesigns »
Under a 1.6TDI you can even mount 10J with just a little change to get the doorcard a bit more in it still let fully slide open the slidingdoor. With the 2.0 TDI 140hp 8,5J already comes out
