Maxi workhorse
- R22LRM
Maxi workhorse
Hi all, so I am now the proud owner of 2no caddy’s. As my candy white Tfsi has morphed into a garage queen, I needed a new workhorse.
Let the mods begin
Let the mods begin
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
Re: Maxi workhorse
Hadn’t even owned this workhorse for a day before the seats had to go ripped the originals out quick clean and bang new gt sport seats for a measly £50, what a difference they make to comfort, probably the best £50 I’ll spend on this van.
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- Ripley55
Re: Maxi workhorse
2 Caddy’s
Now that sounds awesome
I’d love to, but I’m 100% certain, I’d be divorced by the end of the month
- R22LRM
Re: Maxi workhorse
The other half isn’t impressedRipley55 wrote:2 Caddy’s
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
Re: Maxi workhorse
Few little jobs boxed off today:
Van x led winkle pickers:
Caddy alltrack smoked rear lights:
Gti mk5 steering wheel:
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
Re: Maxi workhorse
Next jobs gti breaks & stance coil overs:
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
Re: Maxi workhorse
You are missing the carriers from the rear brakes in that photo, that's essentially the only part you need as the calipers are a different piston size and not suitable for use on a Caddy.
- R22LRM
Re: Maxi workhorse
Ahh ok thanks for heads up doc, so the caddy callipers will work with the 286mm discs if I get the carriers?Doc wrote:You are missing the carriers from the rear brakes in that photo, that's essentially the only part you need as the calipers are a different piston size and not suitable for use on a Caddy.
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
Re: Maxi workhorse
Think I have some callipers and carriers off my white one that had 282mm rear discs on it when I upgraded to r32 rears will they fit the maxi?
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
Re: Maxi workhorse
Without knowing exactly what you have to fit and what is fitted I can't advise 100%, that said I and many others have fitted rear caliper carriers from a GTI and put the caddy caliper onto that without an issue.
- R22LRM
Re: Maxi workhorse
Doc thanks again saved me a bit of head scratching there
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
Re: Maxi workhorse
Freshly painted rims, wrapped in lovely falken rubber ready coils now
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
Re: Maxi workhorse
Easiest modification ever heko wind deflectors:
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
Re: Maxi workhorse
Freshly painted front gti callipers and discs:
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
- R22LRM
