balmay
Hope you don't mind me asking here, will VCDS cable work with ios software or is there any alternative to VCDS that can be used for coding?
- Papa Bear
There is a vcds mobile I believe, works via a web page so works on all platforms
https://www.ross-tech.com/vcds-mobile/vcds-mobile.php
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- ACalamita
I can vouch for VCDS mobile.
I've seen/heard of Carista about on Facebook etc. but I wouldn't touch it personally.
mikeb1810
Today I have removed all the BG racking from the back of the van, given the inside a good clean and am about to start some sound deadening. I think I'll start with the inside of the wheel arches and go from there.
Any specific areas people would recommend?
- Dylwestbury
Finally got some vent adapters
- Towner11
@Dylwestbury
Where did you get the adapters from??
@mikeb1810 one area I’ve found troublesome is the roof. I used silent coat under dodo mat and the silent coat will fall off in warm weather. I’d recommend just using dodo mat or similar on the roof.
Ryzar1
There’s a few people on the forum that can 3D print them bud I got mine from kris perks krisperks@outlook.com you can try and contact him if you likeTowner11 wrote:@Dylwestbury
- ACalamita
I 3D printed a keyring of my van
- Dylwestbury
@Towner11 ye as ryzar said got them from kris perks off Facebook marketplace just look for vw caddy audi vent on there
- Towner11
Brill thank you both
- Cthulu
Just joined this forum and after reading the obsessive posts in this thread, I know I’m in the right place
Caddy 140 6 speed with scum class Startline spec
BC coil overs. Whiteline adjustable ARB. MAM RS4 19” alloys on Pilot Sport 4S tyres. Sirus rear seats. Darkside tune 190bhp
- Cthulu
THIS is why I joined. I’m inspired
- Dubbsley
I wouldn’t be without my Carista now, comes in really handy, it’s very good for amateur as it’s very easy to use, can do some great basic tweaks with it but is no match for VCDS.
- ACalamita
Cool!
That's pretty much what I understood it's use for. Kinda the known adaptations/long coding changes.
Can you "backup" the long code/config prior to re-writing or is it just like tick boxes?
