R8umar
Post by R8umar »
Decided to do the VW badge gloss black and wrap the backing the same colour as the van
Can anyone tell me what I've done to my tailights. They don't light up in the E pattern anymore. This is a genuine mk4 but I have been messing around with some coding so I'm not sure what I have doneImage
lokoli
Engine size/power: 2.0 CNG (107bhp)
Post by lokoli »
Winter wheels fitted today :roll:
BBS SR 17x7.5J ET45 with 235/45/17 tires
caddychris2002
Post by caddychris2002 »
R8umar wrote: Thu Dec 17, 2020 3:24 pm Decided to do the VW badge gloss black and wrap the backing the same colour as the van
Can anyone tell me what I've done to my taillights. They don't light up in the E pattern anymore. This is a genuine mk4 but I have been messing around with some coding so I'm not sure what I have doneImage
Did you do an Auto-Scan and did you save it before you changed the coding? if so revert back to the old code by going into the log and copy and paste it into the new coding box found in the coding section of the correct module if that makes sense? then start again
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
Gwiz
Post by Gwiz »
First mod to my van couldn’t resist as it came off a 2019 seat and was a bargain at £25 squids thanks silverlake ImageImage
deanopolini
Post by deanopolini »
Gave it a well needed wash !
DeanWhit
Post by DeanWhit »
Deanopolini, that's a lovely van.
I have to agree with you there Dean
Treads
Post by Treads »
Tidy
2012 Caddy, 1.6 TDi (needs a chip tune!)
2k12 Natural grey,
102PS,
Side rail cover,
Coilovers & Axle flip,
18” black alloys,
Touran seats, bases, drawers & arm rest.
Colour coded door handles,
Colour coded Touran bump strips,
Auto lights upgrade,
LED interior lights,
Touran mirrors (not yet folding!)
MFSW,
Needle sweep on start-up,
Westfalica removable tow bar & OEM electrics,
Genuine VCDS available if anyone is nearby...
anoneamus
Post by anoneamus »
R8umar wrote: Thu Dec 17, 2020 3:24 pm Can anyone tell me what I've done to my tailights. They don't light up in the E pattern anymore. This is a genuine mk4 but I have been messing around with some coding so I'm not sure what I have done
Strange, AFAIK there's no way to do this via coding. Needs a EEPROM edit via VCP..
RallyeS2
Post by RallyeS2 »
Today cluster replace, Caddy 2K 2005 :D
Old:
"New":
R8umar
Post by R8umar »
caddychris2002 wrote: Did you do an Auto-Scan and did you save it before you changed the coding? if so revert back to the old code by going into the log and copy and paste it into the new coding box found in the coding section of the correct module if that makes sense? then start again
I did it using obdeleven. It had a history mode so I should have my original coding there I'll give that a go. Thanks
R8umar
Post by R8umar »
@anonymous hi, I did try revert back to original but it didn't fix anything. I'm sure where it says new software version I may have tapped that and uploaded a newer version. Could that be the problem?Image
anoneamus
Post by anoneamus »
R8umar wrote: Fri Dec 18, 2020 2:24 pm @anonymous hi, I did try revert back to original but it didn't fix anything. I'm sure where it says new software version I may have tapped that and uploaded a newer version. Could that be the problem?
Possibly. I don't know anything about whatever app you're using, where it gets software updates from or what applying them does to your vehicle. You need to edit the BCM configuration EEPROM and write it back to BCM. AFAIK the only software that can do that is VAGCANPro.
Here is a post I made on the edits that would need to be done:
viewtopic.php?f=6&t=40406
rbu_tuninq
Post by rbu_tuninq »
I 've fitted the low level sensor for screen wash bottle... i just have to try pin 17 on cluster and coding. :)
caddychris2002
@R8umarwhereareyoulocated mate, I have VCP sure I can help you out.
www.dav-tec.co.uk
Mods:
