Axle Centre Plate
IainH91
Axle Centre Plate
Afternoon All,
Best place for axle centre plates and wobble blocks (Thinking about making this up myself, as its just a bolt and some material)?
Cheers,
Iain
Cheers,
Iain
- Giddy
Re: Axle Centre Plate
In general there are two types of centralising plates you may need, depending on your leaf springs. So, make sure you know which type you have before purchasing centralising plates. Few people made this mistake by purchasing the wrong ones.
- Jayofmx
I've a 2012, I got these.. https://www.demon-tweeks.com/eu/forge-r ... forfmaop1/
IainH91
I remember reading this somewhere now you say it. Do you know what the differences are? I will have a look before I order.
IainH91
There big money for something simple.Jayofmx wrote: ↑Fri Feb 05, 2021 9:54 pm I've a 2012, I got these.. https://www.demon-tweeks.com/eu/forge-r ... forfmaop1/
- Giddy
Basically, you have either a bolt that goes through the leaf spring or a locating pin which is on the bottom side of the leaf spring. As a rule of thumb pre-facelift will have a bolt and Caddy 4 will have a locating pin. But the facelift could be either, so best to check.
- Jayofmx
IainH91
A lot of kits on eBay for £35-40 delivered. Could make them myself but for ease and speed just going to buy them.
IainH91
Hi Giddy,Giddy wrote: ↑Fri Feb 05, 2021 10:31 pm Basically, you have either a bolt that goes through the leaf spring or a locating pin which is on the bottom side of the leaf spring. As a rule of thumb pre-facelift will have a bolt and Caddy 4 will have a locating pin. But the facelift could be either, so best to check.
I would assume this is the locating pin type?
- Giddy
Looks like it is. In this case you can drill an offset hole in the bottom plate and position your axle exactly where you need it to be. Pin diameter is 15mm.
Or you can get a ready made bottom plates.
IainH91
So basically modify the plate currently fitted? Is there a calculation on the movement i.e. move the wheel 15mm back, drill a new hole 15mm towards the back of the vehicle?
- Giddy
Yes, if you need to move the wheel 15mm, then drill a hole with a 15mm offset towards the front (doesn't really matter, coz plates are symmetrical). But you have to fit them with the offset hole facing towards the front. It will make sense as soon as you'll start doing it
- Giddy
That's with a 20mm offset, just to give you an idea
IainH91
Thank you. Towards the front of the car, trying to picture it and work it out...haha
Reason: Removed the unnecessary quote
- pepi_cro
So if i understand correctly if you have pin you need to drill a hole only on one plate, but it you have screw you also would need to drill hole or wide it also on third plate that goes last, the bottom one?
