I ordered a lot of parts for ventilated front seats:
- 1J0971974
- 3B0972722
- 3D0963345
- 3C0959581A
- 3C0959582
And I took some photos to identify differences between Passat B7's and Caddy's circuit.
Haven’t done anything for a while & won’t be either, I have decided to sell up & move on, just haven’t gelled with it as I was hoping to, will get a full Ad up at the weekend once I given it a clean.
Ive booked it in for a new cambelt waterpump and new aux belt to be fitted for next tuesday and when it's back it's getting some TLC as i've been busy the inside is getting more like a builders van (i know that's my job) the dust has built up in the cab and looks terrible now so wednesday coming out with the hoover give everything a clean and polish and the outside will get a good clean to remove the mechanics grubby prints off the paintwork
Installed MK4 golf pd130 engine cover to my asz engine conversion. Had to cut it abit where the cold air feed .
the engine sits differently in the caddy bay then it did in the golf bay! Way lower,
might consider doing a 20mm spacer lift on the engine mounts although it doesn't look any lower down then the bls engine did
