Oldgregg
Post by Oldgregg »
4 new tyres (michelin pilot sport 4) and fitted some genuine mud flaps, I’m going to have to modify the fronts as they leave hardly any clearance or just remove them.
Yesterday and Today ...
Fitted Rear Cam Button (ParkPilot)
Fitted Aux Battery Power Button for Head Unit power (Heated Window)
3 extra relays - 1x Latching+Std. Combo. and an electronic latching relay.
https://www.caddy2k.com/forum/viewtopic ... 22&t=47327
Peng
Post by Peng »
Picked up a set of coilovers. Is it worth getting adjustable drop links for the front? Or standard's are ok with it being lowered?
AKG86
Post by AKG86 »
Wired in a Split relay. Electrics are next!
MrTmann
Post by MrTmann »
Evening everyone today I removed the bulk head and started sound deadening.Image
Ripley55
Post by Ripley55 »
Laborious job of fitting centre caps to my new Audi 18’s ImageImage
Tried finding some caps on eBlag, and nothing fitted properly Image ended up just getting some domed stickers and using the OEM Audi caps, after taking of the Audi rings. Lovely ride on these new wheels, but need to clearance the inner arches a tad as with 245’s I’m rubbing a bit. Not going to do much to her for a few weeks, as all focus is onto my old Beetle, then it’s new arches and possibly big brakes for the Caddy ImageImage
RY_VW
Post by RY_VW »
Took it to loughborough to get it's new seats, 4 hour trip there and back. Worth it for the price and conditionImagebest photo I can get with the sun outImage
Sent from my SM-A202F using Tapatalk
More to follow 8)
gingerrob
Post by gingerrob »
fitted my life rear seats (dropping tank easy, getting tank back in not so easy on your own!)
tried and failed to figure out the factory seat belt mount point for the end under the step trims!
really frustrating me now!
Treads
Post by Treads »
Peng wrote:Picked up a set of coilovers. Is it worth getting adjustable drop links for the front? Or standard's are ok with it being lowered?
Adjustable. Here in Germany it states that they need to be reduced in length otherwise they don’t pass TÜV inspection.
Im pretty sure that standards will rub anyway
2012 Caddy, 1.6 TDi (needs a chip tune!)
2k12 Natural grey,
102PS,
Side rail cover,
Coilovers & Axle flip,
18” black alloys,
Touran seats, bases, drawers & arm rest.
Colour coded door handles,
Colour coded Touran bump strips,
Auto lights upgrade,
LED interior lights,
Touran mirrors (not yet folding!)
MFSW,
Needle sweep on start-up,
Westfalica removable tow bar & OEM electrics,
Genuine VCDS available if anyone is nearby...
Newtothisr20
Post by Newtothisr20 »
Took van in to garage for vacuum actuator problem. Now being told I need a new turbo.
Do I
A. pay £850 for standard reconditioned turbo oil n filter swap n labour
Or
B. Do pay £400 for upgraded turbo. And labour to have dpf n erg removed and remap I think maybe £1000 total.
Bear in mind engine has done 197k.
Advice would be appreciated
That's a good turbo, it did well.
I'd go with a refurbished/remanufactured replacement if you can find one, I don't see much point putting new turbo on a 200k mile ish engine.
Adding a hybrid at that kinda mileage will only cost you more in the long run. Most likely causing clutch/flywheel problems but maybe even engine problems.
MikerBike
Post by MikerBike »
Fitted roof rails and a new Pioneer CarPlay head unit - more style & better sounds!
2012 Caddy Maxi 1.6TDi 102bhp
Spent the last few days making a box for the back ...
Finished and fitted today
Katiecaddy
Post by Katiecaddy »
@ petrev
Box for the back looks great, like the look of the switch button, where about’s is that from?
Hi KC,
eBay
Search - Push button catch lock
Mine are the larger size as small/mini tend to have more problems for me.
These are the ones I bought last year
Round, Brushed, x5
https://www.ebay.co.uk/itm/263875057212
Others may be cheaper now ...
