purplebaghera
Post by purplebaghera »
Wobble blocks fittedImage
Wobble blocks fitted and dropped one hole, hopefully tightens things up a bit.!Image
Papa Bear
Post by Papa Bear »
Got my Caddy back on the road thank f###
Gearbox all working, mechatronic box flushed and filled, fixed issues. Drives better than before it blew.
Now to strip the old gearbox just to find out what went wring. Maybe make it into a coffee table :D
Black
Marmite lover!!!
VCDS
MFT
Post by MFT »
@Papa Bear - Nice one, very pleased for you. I admire your perseverance.
Mark's Caddy: 2020 Maxi Life 2.0 TDI 6sp DSG 102 PS Indium Grey Metallic (Wheelchair Accessible Vehicle)
RY_VW
Post by RY_VW »
Gave it a well needed but quick wash. Needs a machine polish really and some love. Also had the Mrs nail varnish on the engine coverImage just waiting on mounting pegs to fit. ImageImage
Sent from my SM-A202F using Tapatalk
More to follow 8)
Gazear
Post by Gazear »
Fitted an RCD330 head unit and turned some options on with Vagcom
2012 LWB 1.6 101 blue. Not a BG van.
Sommarstrom
Post by Sommarstrom »
The las few days i have installed a Xtrons head unit, MB Quart door speakers, Rear view camera and Quad Lock wireless charger. Next will be sound proofing and subwoofers. Image[/img]
purplebaghera
Picked up one of theseImageImage
Rickzayne
Post by Rickzayne »
Where from? Do they do one for the other side as well?
I opened the fuse box hatch to try install my dashcam then changed my mind… maybe tomorrow
Reason: removed quote
Markyk
Post by Markyk »
Tested out my snow foam nozzle and foam from InfinityWax! Awesome stuff! Vans gleaming :D
purplebaghera
Hi rickzayne, many a topic on dash cover,quite rare part, found mine on eBay, was pretty lucky
Bjoates
Post by Bjoates »
So went digging this morning trying to figure out why the number plate lights wouldn't work, cleaned the contacts, no change, then got the meter out and there wasn't a Meg out of themImage took off the rear cover and found that the cable wasn't plugged in after someone had the rear number plate lights holders outImageImage
Plugged it in and all good, also replaced a few blown blubs and cleared the fault with my new caristaImageImage
Sent from my MAR-LX1A using Tapatalk
ECUMotorsport
Post by ECUMotorsport »
I bought brand new headlights and converted them into BiLED :)
Caddy IV / 2.0TDi 198KM / 4Motion / White / BiLed Retrofit / 18” VW Alloys 8Jx18 ET51 on 225/40/18’s
Simonh23
Post by Simonh23 »
purplebaghera wrote:Wobble blocks fitted
How have you found these mate, has it been notably more stable?
Reason: reduced the quote
Jeff007
Post by Jeff007 »
Fitted curtains and drilled thru a wiring loom.
Gazear
Post by Gazear »
Booked a remap for next week
