Posts: 2302 Joined: Sun Apr 26, 2015 1:41 pm
Post
by petrev » Wed Jun 09, 2021 12:24 am
@jeff
ARRGH !
Curtain pics if you can ?
Jeff007
Posts: 23 Joined: Mon May 10, 2021 7:17 am
Post
by Jeff007 » Wed Jun 09, 2021 5:05 am
St
St
A
Still got the rear sides and cab divider to go. Plus the riveting for the press studs. This end was where I went thru loom. Was gonna glue them too.
Post
by petrev » Wed Jun 09, 2021 10:28 am
Thanks for the pics
Lots of fun fitting them ...
RY_VW
Posts: 492 Joined: Sat May 02, 2020 8:37 pm
Post
by RY_VW » Sat Jun 12, 2021 7:37 pm
Little doofers finally came to fit it so on it went, couple of scratches + more now from dropping it on the gravel
not bad for £30 though. Just need the oil filler ring now
Sent from my SM-A202F using Tapatalk
More to follow
Markyk
Posts: 9 Joined: Thu May 13, 2021 12:48 pm
Post
by Markyk » Sat Jun 12, 2021 11:02 pm
Fitted caddy life mirrors and side door rail covers
mirrors were a swine with the various antennas and such that needed swapping over but got there in the end!
DjLoop
Posts: 54 Joined: Sat May 29, 2021 11:28 pm
Post
by DjLoop » Sun Jun 13, 2021 6:52 am
Try to make lock mechanisem work with 2019 dorrs on. 2008 caddy
Vw Caddy 2008 Carrera Cup Showcar/Db Drag/Demo car
1200Ah Winston Lifepo4 Lithium
114kw in Amplifier power
140m 40 x 40 Steel reinforcement
Bullet Proof Glass "14mm"
370a Mechman Alternator
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
038 130 073AL injectors
Turbo GTB1749V
Full Powerflex
Jono1
Posts: 201 Joined: Mon Jan 04, 2021 1:35 pm
Post
by Jono1 » Sun Jun 13, 2021 7:10 pm
@markyk
Where did you get the rail covers from?
Mirrors look spot on aswell.
Both top of my list
Markyk
Post
by Markyk » Mon Jun 14, 2021 7:52 am
@Jono1
Hi man
I got them from a guy on fb. He also lists on eBay here’s the link. This is for the maxi x2 rails. He offers them plain or painted.
https://www.ebay.co.uk/itm/VW-Caddy-2K- ... 890.l49286
Mirrors also from him
Giddy on Mon Jun 14, 2021 7:52 am, edited 1 time in total.
Ryzar1
Posts: 639 Joined: Fri Aug 16, 2019 12:22 am
Post
by Ryzar1 » Tue Jun 15, 2021 12:14 am
Just thought I’d post an updated picture of my caddy
Ryzar1
Post
by Ryzar1 » Tue Jun 15, 2021 12:15 am
My coil overs should arrive soon I’ll post another pic with it lowered
Post
by petrev » Tue Jun 15, 2021 4:41 am
Looking good
Tagllana1
Posts: 46 Joined: Sun Apr 14, 2019 10:43 pm
Post
by Tagllana1 » Tue Jun 15, 2021 2:42 pm
Hi @Ryzar1, did you get the side window fitted yourself? If so, can you point me in the right direction please?
Tom
Gazear
Posts: 42 Joined: Sat May 22, 2021 10:25 pm
Post
by Gazear » Tue Jun 15, 2021 5:16 pm
Well I broke down clutch pedal on the floor. So either master or slave cylinder has gone.
2012 LWB 1.6 101 blue. Not a BG van.
Ryzar1
Post
by Ryzar1 » Tue Jun 15, 2021 10:22 pm
Tagllana1 wrote: Hi @Ryzar1, did you get the side window fitted yourself? If so, can you point me in the right direction please?
Tom
Side window was already there mate but I’m thinking of picking up another side door with the better looking window
AKG86
Posts: 13 Joined: Fri May 07, 2021 7:18 am
Post
by AKG86 » Tue Jun 15, 2021 10:26 pm
Washed and machine polished. Also finished carpeting the back.
