Lister79
Posts: 2200 Joined: Fri Jan 20, 2017 8:38 pm
Post
by Lister79 » Wed Jan 19, 2022 2:00 pm
Good to see you putting the effort in to back date the build thread, keep it coming
J_Con
Posts: 608 Joined: Thu Oct 12, 2017 9:52 pm
Post
by J_Con » Wed Jan 19, 2022 5:03 pm
Thanks Chris, thought it was time to start one as the caddys came quite far and not everyone is on Instagram so plenty more to come
J_Con
Post
by J_Con » Wed Jan 19, 2022 6:26 pm
A before and after of my new front brake set up, also coated in KKD Revolve. These were refurbished by bigg red in Worcester
J_Con
Post
by J_Con » Thu Jan 20, 2022 8:45 pm
Thank you @Mpowerkits&coding
J_Con
Post
by J_Con » Thu Jan 20, 2022 10:26 pm
Slip ring changed to a highline for the MFSW
Polo AW wheel fitted with a 3D/Colour cluster
golfman
Posts: 39 Joined: Sat Oct 12, 2013 9:13 pm
Post
by golfman » Fri Jan 21, 2022 3:57 pm
That Steering Wheel looks absolutely Mint
gpaolo2kn
Posts: 66 Joined: Tue Dec 28, 2021 5:54 pm
Post
by gpaolo2kn » Fri Jan 21, 2022 4:44 pm
wow! the polo steering wheel is really nice. mounts without modifications?
J_Con
Post
by J_Con » Fri Jan 21, 2022 10:01 pm
@golfman I suppose it was alright
J_Con
Post
by J_Con » Fri Jan 21, 2022 10:03 pm
@gpaolo2kn yeah it's a straight fit
J_Con
Post
by J_Con » Sun Jan 23, 2022 7:01 pm
J_Con
Post
by J_Con » Sun Jan 30, 2022 4:08 am
Plastics and headliner removed to colour match.
I also used scuff paste and a scotchbrite pad for the plastics first
U-pol plast adhesion promoter and U-pol plast dark grey for the plastics and autobrite dye for the headliner.
Touran centre console fitted
Sent from my SM-T813 using Tapatalk
suzierobs
Posts: 21 Joined: Fri Aug 06, 2021 5:51 pm
Post
by suzierobs » Sun Jan 30, 2022 10:08 am
Looks great
When you fitted the engine cover, did you need any fixings, or did it just clip straight on?
I’ve got the same engine (I think), here’s a pic - would I need to get fixings or just the cover?
Thanks in advance for your advice
Engine bay
J_Con
Post
by J_Con » Sun Jan 30, 2022 10:47 am
@suzierobs thanks!
The oil ring isn't needed to make the cover fit but stops spilt oil so worth doing imo, part number is 03L133287, and you'll also need 2 Mounting Ball heads, part number is 03L103164
J_Con
Post
by J_Con » Mon Feb 07, 2022 9:22 am
Bad snow last year and soon as I took the van off the drive the coilover had snapped, can see how much lower the front is
