New to me Caddy and central locking
Lomax
Post by Lomax »
Evening, Unfortunately i can’t see all posts as I am new.
I picked up a 2011 caddy today and it looks to have touran door cards fitted. The windows go up and down fine, but the central locking doesn’t work on the two front doors, the rears lock fine.
Also when I lock off the key the passenger door doesn’t lock.
Can anyone help with some advice?
Re: New to me Caddy and central locking
Welcome to the forum.
Sounds like the typical scenario where someone has fitted old door control modules on a new vehicle. The wiring to the door modules from the locks changed around 2008, if the wire positions are not changed to suit the modules as part of an electric windows retrofit, the locking won't work.
You won't have access yet but the information is in the technical section of the forum for you once you meet the requirements.
Lomax
Post by Lomax »
Many thanks for the reply. I take it I need to post x amount of times to meet that criteria?
I don’t suppose anyone could share the wire arrangement that I need?
Lomax
Post by Lomax »
I found a guide on YouTube, but the problem is someone has been at the wires already and they are not in the correct starting point order.
Would anyone know what white numbered wire goes where into each pin?
That would help me a lot.
