Lockstock
@pman1984
I used those exact runners to build a drawer into my caddy.
You my find you struggle to get the rearmost screws through the runner, into your (tray, drawer, bed)..
Hopefully its close enough to tailgate you will have clearance. I had to mount mine onto a false floor, then slide the whole unit into the caddy and bolt to the floor, or I couldn't secure runners at the back...
Yay.
New black letters for my YDDAC
shameus
More trimming…
mangrovejack
Did a whole bunch of sound deadening and thermal insulation. Here's a few snippets. You can see more images in my build thread.
Installed a dashcam
MLV
Installed a dashcam
MLV
2012 Maxi build thread - https://www.caddy2k.com/forum/viewtopic ... 13&t=50069
Instagram account - https://www.instagram.com/stealth.caddy/
Peperito
Hi all I was lining the entire interior... Chinese work...
- J_Con
Parked up at Kulturshock in Gateshead for the show tomorrow
- C Chis
Good luck for tomorrow !
Lockstock
replaced my broken rear window. not the best job sadly.
I got aftermarket glass from Vanpimps. Very good price, and very good quality..
I fitted the glass, only to find it sits slightly proud of the main barn door glass.... Then I notice, despite being a good fit... the vanpimps glass is almost twice the thickness of oem VW.
So, I'd highly recommend the glass, if replacing both barn doors.. I'll learn to live with it for now
- J_Con
Cheers Colin, alot of nice cars!
- RKDesigns
With these bumpers you need side skirts, van will look lower that way as well.
Have a nice showday!
- J_Con
@RKDesigns I do Ron, I'll be in touch shortly they are next on the list
lsm
lots of great ideas and workmanship on this this thread
mangrovejack
Carpetted the front parcel shelf to better blend in with the back of the van. The 4 way stretch carpet did the trick very nicely.
- S400ASP
Got the under seat sub fitted behind the passenger seat. Sounds a lot better
- slayerklx
Did a trial fit of my new 996t brakes, just waiting on some longer caliper bolts then they can go on properly
