delvey91
Finally sorted my radio today so the first time since July I have radio signal !
m-racer
I tried to install my passat b7 (2012) front seats to my 2011 caddy. But they didn't fit at all. The railings are different. So, bye bye heated seats.
Don't know the B7 seats specifically, but most VW seats will fit a Caddy if you use a Touran seat base instead of the std. Caddy base.
The rails are normally about 10mm wider than Caddy/Polo/Ibiza/Fabia rails - The Touran bases mount to the Caddy using the same fitting holes (indeed Touran bases are used for Caddy Mk4 Comfort seats).
Some people have simply drilled new holes in the rails (or seat bases ?)
Stubbs
Spent a worthwhile couple of hours this afternoon pulling out the BG wiring additions.
Glad I did as on top of the isolator board and relay it had half a hands free kit still ratting around behind the dash and worst of all at least 3 permanent and switched lives from the sub-fuseboard just cut-off and hanging bare in the breeze in the rear
Touran rails mentioned sound like a good plan - it sounds like they should fit most VW seats right?
m-racer
I am now looking for used touran seats with heating and this folding mechanism. Could take a while...
- gazza31112
Got back to the wrappers for a good clean and some photos
@m-racer
You probably just need the seat bases from a Touran and then you
should be able to fit the Passat seats !?
All assuming the Passat seats are just a bit wider rails and M10 bolts ... Like most VAG seats.
Oooo Gazza - That is lush
- Jonhall
Installed a mains hook up ready for this season’s camping adventures
Managed to fit a mini consumer unit, leisure battery charger and additional 13A socket behind the driver’s seat, with the 16A connection under the bonnet.
MkIV (2017) Caddy Maxi Highline 2.0TDi 150bhp DSG
m-racer
Thanks for the information. I made a quick search and these consoles are more expensive than a complete seat.
If you can find the seats you want with bases for less then yes
- Robert VW
Manual hand wash and polish.
Looks just perfect now.
- Caddy Dan123
Thanks to a very good buy from @Gresley finally got the touran mirrors fitted to my mk4 caddy.
Sent from my SM-G998B using Tapatalk
- Gresley
WFBryn
Wow! Gotta love a good ocd clean - that's looking nuts, nice one
