Gwiz
Post by Gwiz »
Ellis667 wrote: Tue Mar 28, 2023 5:35 pm Do the grill trims just pull off or need to remove from clips with trim tool?
There’s clips under the trim you need to push each one in as you pull it up as theres hidden clips that you can’t push you don’t need any trim tools or need to take the grill off and I found it easier to start from the head light and work in towards the badge . It only takes 10 minutes to do bud.
PaulC61
Post by PaulC61 »
DeanWhit wrote: Mon Apr 03, 2023 5:16 pm Just spotted some bloke taking pictures of the van… not sure if I should be proud or super suspicious. 😂
I had this a few years back. Stopped off with the other half at a certain chain of coffee shops and had to bump half up on the island in the car park. The Caddy was all spangly clean plus with it leaning slightly over on the island the thing looked more lowered than it actually is. Next thing we looks out the window and there is some guy doing selfies in front the Caddy.
mikenorman
Post by mikenorman »
Bought a bit of a sh1t box a couple of weeks back but it’s mechanically in good shape.
So far I’ve rebuilt the headlights, put 18” smoothie wheels on and carpeted the rear. It’s booked in for a respray in two weeks and lowering the week after that. I’m going stealthy and clean with this one…
Will post up some before and after photos ones it’s done
WTTN x
Post by WTTN x »
Almost 2 years late for the party but I’m finally going to start carpeting and insulating the back of the maxi today 😁 getting prepped for festival season!
Bluemooner
Post by Bluemooner »
WTTN x wrote:Almost 2 years late for the party but I’m finally going to start carpeting and insulating the back of the maxi today Image getting prepped for festival season!
Better late than never ...just got these back from the powder coaters..so I need to crack on with the spring flip and coil overs Image
Sent from my Pixel 6 using Tapatalk
Post by stu_b »
Nice wheels
Only 92Y ?
Bluemooner
stu_b wrote:Nice wheels
Only 92Y ?
The tyres came with the wheels ..like new !! Not planning on weighing the van down too much and with the 1.6 diesel I don't think the upper speed limit will be an issue Image
Ricksy1121
Post by Ricksy1121 »
92 is not enough for a maxi rear, 93 or over is correct for the maxi rear axel. Just be aware the van should fail its mot with a 92 load rate on the rear.
2018 Pure grey ea888 gen3 TSI
Bluemooner
Mmm right I'll have a look at that .. even if the caddy is registered as a camper and wont have that kind of weigh in ?
Lockstock
Post by Lockstock »
Bluemooner wrote: Fri Apr 07, 2023 7:40 pm Mmm right I'll have a look at that .. even if the caddy is registered as a camper and wont have that kind of weigh in ?
all that matters is the Gross Vehicle weight on the V5, it's irrelevant whether it's at capacity.
The only times these things matter if you are in a bad accident. is it worth saving a few quid on tyres, or getting a certain 'look', to risk ending up uninsured and facing jailtime??
Post by stu_b »
Hey bluemooner
Sorry man, didn't mean to throw u under the bus !!
I am new to all this Caddy stuff
Regardless, the wheels look schmick 😉
Seems they do need to be higher rated ..
Question is, do they make that same wheel / profile brand etc in a 93+ ?
Also, can the 92Y be used on the front ? If so, they can be a spare pair and just need to change the rear
Hope it all works out
Bluemooner
No don't worry ..I'm new to this and all advice welcome and appreciated.. the tyres were virtually new so really I could sell those and get the higher rated tyres .. the guys that I bought the wheels /tyres off are the guys that did the powder coating and are really on the ball .the wheels are off a Skoda Octavia so should be able to track down correct tyres for the caddy maxi
Post by stu_b »
I'm sure they'll probably do a straight swap over (maybe a few extra squid) as they can sell them over n over again while u get the right load rating
Fingers crossed 🤞
Ricksy1121
There will be more options for 93 if you go up to 235 wide. I run a 235/40/18
Check the Type Plate for rear axle weight
Some are plated at 1250Kg (apparently) which would be just inside 92 Rating (1260/630)
