Our Caddy / Camper / Day van
Good afternoon all,
Will update this as we make changes to it, but we've tried to utilise it as a camper but retain the 'van' aspect of it.
It's currently sitting on some coilovers (cant remember which ones she bought!), 330mm Forge Motorsport brake conversion, remapped, Golf R steering wheel with flappy paddles
The 'box' that acts as a bed
and it managed to fit in the worlds biggest magnolia & a wheelchair
Next up is a Bi-Xenon conversion and a split relay charger - not looking forward to that!!
- Jonhall
Re: Our Caddy / Camper / Day van
Tidy van! Looking forward to seeing how this progresses
If the van is Euro 6 (and has a ‘smart’ alternator), you won’t be able to use a voltage sensitive relay for split charging. Instead, a DC-DC (battery to battery) charger is required to manage the charging of the auxiliary battery. Lots of options available from Victron, CTEK, Sterling etc but they are costly compared to a simple VSR set up on an older van.
Loads of info here to get you started: https://www.12voltplanet.co.uk/kc-split-charging.html
The cable routing from the engine bay into the cabin is easier than you might think
MkIV (2017) Caddy Maxi Highline 2.0TDi 150bhp DSG
Thanks!
Although a 66 plate, it’s not a bluemotion- not sure if that makes it euro5 by default?
I believe this is a byproduct of the dsg gearbox, the model description is suffixed with s-a where manuals don’t appear to be.
Any way of checking on the vehicle physically to know if i can just use a VSR?
- Jonhall
Have you run the reg through a CAZ/ULEZ checker? If it’s exempt from charges, it’s almost certainly Euro6.
That said, I don’t think you can use a VSR with a Euro5 engine either for the same reason (highly variable voltage off the alternator) but I haven’t researched that in as much detail as mine is Euro6 (2017 2.0 TDi 150 DSG, not BlueMotion).
Does it have adblue?
How do you like the brakes? It's time for me to upgrade mine.
https://tfl.gov.uk/modes/driving/check-your-vehicle/
No it doesn’t have adblue, but is fully ULEZ compliant.
The brakes are fantastic! Albeit expensive & not much by way of competition for pricing!
I’d probably opt for a VAG bbk for that reason but I can’t complain about the quality.
Cheers dude
Nice looking van.
Mine is also a 2016 with no adblue and is ulez and clean air zone compliant.
This is exactly what I would like to do to mine. Did you make the storage/bed unit yourself? Nice flooring pattern design too. Where did that come from?
cyderspace wrote: ↑Mon May 01, 2023 9:30 pm This is exactly what I would like to do to mine. Did you make the storage/bed unit yourself? Nice flooring pattern design too. Where did that come from?
She got the box from ebay, was fairly cheap tbh but she wants to get one from evo design now... Seller :
https://m.ebay.co.uk/seller?sid=mrcncman
We had custom dims made up, Width 117cm x Depth 80cm x Height 45cm.
The vinyl flooring came from here - https://www.ebay.co.uk/itm/112499464516
I've now been told that leather seats are far more important than xenons ('cos it's bright)
So now I need to source some that look new and also fit them.
I'm still off work after my operation, so now is the time to look to do it, she's also back home in Poland, so there's an even bigger expectation
Of course, every seat I find isn't good enough, or too expensive.
I don't have this issue with my 911, I just buy whatever i want, I'm far less fussy!
