Just another camper build
paddythecaddy96
Re: Just another camper build
Post by paddythecaddy96 »
3rdLeg wrote:Mate we could get those wheels looking way better if you can be arsed?! Need to spend more time on the prep Image
Have any tips for the prep? I used a couple of different grits of sandpaper (80, 100, 120) and I know there’s still a few lumps and bumps. Would especially appreciate tips for getting in the harder to get bits in the deeper down areas
3rdLeg
Post by 3rdLeg »
Try different size wire wheels on a drill/grinder (protect your eyes!)
Get the tyres properly masked up and protected with tape/newspaper etc after prep, before primer/paint
If you’re using gloss black that’ll highlight imperfections more than satin/matt
Plenty of how to’s on YouTube
paddythecaddy96
Cheers mate, still have 4 more to do so will hopefully get a bit better! I'll get some satin/matt in that case!
paddythecaddy96
Got round to fitting the curtains last night, hopefully keep everything nice and dark in the back!
3rdLeg
Post by 3rdLeg »
paddythecaddy96
And then spent this afternoon cutting and sticking. Put a few of the bits in a rough form of what the aim is, we’ll see what happens over the weekend though!
paddythecaddy96
We’ll, after a few late nights and early mornings, we got there. Image
And then woke up in Cornwall this morning!!Image
All in all, quite stressful week but holiday mode for a few days now Image
3rdLeg
Post by 3rdLeg »
Well jealous! Love a dip in the sea at the moment.
Enjoy 👍
TheGrinch
Post by TheGrinch »
How do you like the curtains? They look cool but I opted for insulated thermal mats to cover the windows. I cant help but think I could of had darkness for less money but hey maybe warmer in winter and cooler in summer?
paddythecaddy96
@3rdleg, it was so nice, was my first time in Cornwall and already excited to go back! Image
paddythecaddy96
To be honest @thegrinch, price wise they seem to be very similar, there’s just a bit of work to be done with the curtains. Rails need bent and cut to shape, drilled in etc., they did keep it really dark which was nice and there was a bit of a temperature difference between the cab and the back, but not a massive difference. I’m sure when it’s gets a bit colder, it would worth having both though.
paddythecaddy96
Getting on with more of the wheels, looking better than the fading paint job they had! Also picked up a decent set of caddy life bars recently and got them on, just waiting on more wee blanks to arrive for the holes left by the lovely people over at BG. Image
While going through the wheels its stood that a couple have definitely seen better days with quite a few dings here and there
I guess that means we’ll just have to get some alloys much to the mrs’ dismay!
tippo
Post by tippo »
Hi,
how did you insulate the roof? From the pictures it looks like both this silver stuff and white polyester? Glued or clamped into place? How thick?
Cheers Johan
2014 Caddy Maxi Life 2.0 TDI - Stealth Camper
paddythecaddy96
Hi Johan! I used some sound deadening which is roughly 2mm, followed by the thermo liner which is about 10mm, these both have peel off bits on the back and then it just sticks up like a sticker. The white liner is about 50mm thick, and just stuck it on with some trim fix that came with the carpet.
https://www.dodomat.com
tippo
Post by tippo »
Thanks! :)
Does the thermo liner acts as vapor barrier, or did you put something under (above) the T&G ribs?
