TheGee
Post by TheGee »
I had the bright idea to custom build my headlights again ImageImageImage
Instagram @g_giotec
New build thread >>HERE<<
kazzi
Post by kazzi »
Made the cutout for a switch to manually turn on, off or leave on auto the rear reversing camera Image
Sent from my 2201116SG using Tapatalk
I've got one of those manual On buttons for my rear camera too.
Very handy.
:thumbsup:
Momo Signs
Post by Momo Signs »
Got some polish on my lenses...
Before:
After:
Rabswan
Post by Rabswan »
Lowered it, went with some coilovers.
Fitted new discs and pads all round, droplinks, wishbones and of course top mounts as standard.
Really happy with it now.
Post by stu_b »
Those lenses / lights have come up pretty good
like factory oem
what did u use / how did u do it ?
Momo Signs wrote: Sat Aug 12, 2023 10:37 pm Got some polish on my lenses...
Momo Signs
Made a big difference hey. Used menzerna heavy cut compound andmedium cut polish on a polishing wheel attached to a drill. Loads of passes working the Product in at a relatively slow speed making sure the lens didnt get hot
Post by stu_b »
don't suppose you took any videos of your handy work
did you use these two compounds at the same time ?
Momo Signs
I didnt sorry mate. Used the heavy cut compound first on a medium pad (make sure there's plenty product on the pad to start with, dont want dry patches causing friction/heat) and work it in at a slow speed (keep feeling the lens just to make sure you're not getting it hot). Couple of passes working the product in well then buff off. Repeat with the medium compound. Ideally finish off with a finishing compound and some wax to gi e it some UV protection
Post by stu_b »
well with those efforts it's no wonder you got great results
Jca730
Post by Jca730 »
1st proper drive since I had 2 new injectors fitted (1.6tdi) and fuel economy is back to previous levels. Should have realised something was wrong when I was only getting 30mpg
kazzi
Post by kazzi »
Fitted touran passenger seat on my lunch break at work, will do drivers tomorrow, nice little upgradeImage
raitis
Post by raitis »
Upgraded my CAN gateway to a 7N0 907 530AC from a 2012 Touran. My 2008 van finally recognizes the RNS-315 through VCDS, but the vehicle speed dependent volume feature still does not work. At least I could disable DAB radio which is not in use where I live.
I also bought Midline Touran clocks to replace my poverty spec base instrument cluster. I wanted Highline clocks, but there were none available at any local breakers since I need the pure petrol version. Now, there is a problem finding people who could swap over the data from my old Lowline clocks :oops: It should be simple enough, using Vag-Tacho, right?
Vag-Tacho won't do much for a 2008 instrument cluster, those use immo4c which has encrypted data requiring some specialist tools.
enk005
Post by enk005 »
Not the most exciting thing to do to your van but it was annoying me none the lessImage
