The van gods will be feasting this evening, they have an entire Touran's worth of spare bolts to enjoy
- Bahnstormer
Thanks everyone, it's been quite the roller-coaster
wicksta
Lowered my van at the weekend, using Eurocar parts JOM kit https://www.eurocarparts.com/p/jom-susp ... 975449271 - which is the same as the Stance + kit (even down to the stickers) but in silver/blue. It was cheaper than the Stance+, £290 when they had a sale discount code the other day, plus in stock locally.
Also fitted some 17 inch Audi Q2 wheels/tyres which were going cheap on Facebook marketplace.
Still need to replace one rear shock, the 21mm bolt at the top is being a pain! But it was too cold today.
Looking good.
Nice wheels
Like the Black and White look
Nice wheels
@ Philsparky - what thickness is the boards on the back doors, are they the originals carpeted or did u opt for something thicker ?
- philsparky
they are original, i bought the one with the handle cutout on ebay
Here
Here
2017 Caddy Trendline 2.0TDI 102ps, Reflex Silver
D866
Got my cruise control working in 6th gear on my BLS Caddy. Also fitted my leisure batteries, dc dc converter, fuse board and Anderson plugs in back for my fridge.
D866
Where did you get the door seals Chis? I fitted some generic ones but would get the real deal if possible.
- C Chis
[mention]D866 [/mention] from LLL Parts.
Part numbers
Volkswagen Door Seal, Outer 2K0837701, left hand side
Volkswagen Door Seal, Outer 2K0837702, right hand side.
£48.53 for the left hand side, I assume the same for the right hand side.
Delivery was almost as expensive at £31.31! Best to wait until you need a few bits!
Part numbers
but no mention of thickness on LLL or eBay
this is my question.....
- philsparky
[mention]stu_b [/mention] the factory panels are ~2.6mm thick, with carpet about 4.5mm
@philsparky thank mate, hard to imagine someone cutting / making a piece of wood 0.6mm thick (2.6mm)
you almost double it with carpet
I am thinking to use thicker ply so I an mount stuff on it
cheers for the answer
- philsparky
I only used the original panels so the genuine handle surround would "fit", I had to fettle it to take into account the carpet thickness too
I think I would either have to router out the thicker panel or opt for the less attractive / non oem looking lanyard version or similar
If I was to router it out then the whole handle would probably sit flush if not countersunk
- gazza31112
Much needed new set of falcons
