C Chis
Posts: 1688 Joined: Fri Mar 06, 2020 1:13 pm
Post
by C Chis » Thu Jan 25, 2024 5:22 pm
Simple fix that’s been on my list for ages…
Sliding door stop replaced with a new one from VW, no more holding it open with my shoulder
Next job is a replacement RLS to fit in the factory bracket on my replacement windscreen and the a bit of a touch up to the sliding door sill from previous bottom roller failure
My VR6 Build Thread and Details can be Found
Here
Projectil_CZ
Posts: 12 Joined: Sat Dec 23, 2023 7:09 pm
Post
by Projectil_CZ » Thu Jan 25, 2024 7:18 pm
Went to the part store and found this
HP2 brakes for 314x30mm brake discs
mac12
Posts: 81 Joined: Thu Sep 28, 2023 8:47 am
Post
by mac12 » Thu Jan 25, 2024 8:56 pm
I've tried to repair my defroster wires in my rear window with Loctite Circuit +, but the masking tape just tear off the tracks when I try to remove them. Think I'm doing more harm than good at this point
kryton85
Posts: 118 Joined: Fri Nov 24, 2023 9:43 pm
Post
by kryton85 » Thu Jan 25, 2024 9:01 pm
Put it next to the element (each side) to create a thin line then remove whilst still wet. Not used the loctite but if it’s the same as other stuff, if you peel when it’s gone hard, the stuff that overlaps the tape lifts with it. If you pull it off when the repair is wet, it comes straight up
mac12
Post
by mac12 » Thu Jan 25, 2024 9:58 pm
Which one did you use? the Loctite one is expensive as hell. 22£ for 5ml.
kryton85
Post
by kryton85 » Thu Jan 25, 2024 10:08 pm
Pass. Was on Amazon & several years ago. Link now broken but order summary says
Front Or Rear Car Heated Element Demister Line Brake Repair Kit Paint On Glue £10.95
Was A LOT more silver than factory but worked perfectly fine
mac12
Post
by mac12 » Fri Jan 26, 2024 1:28 pm
Cheers! Found some cheaper alternative on Amazon. I'll get one of those circuit testers, and then just go to town on the defogger.
Posts: 5153 Joined: Sat Feb 18, 2017 10:52 pm
Post
by the swan fiend » Fri Jan 26, 2024 6:33 pm
Gave it a wash and blew some paint from my front bumper with the pressure washer. Gutted!
Poffe
Posts: 215 Joined: Fri Nov 17, 2023 7:05 am
Post
by Poffe » Sat Jan 27, 2024 6:26 pm
I feel your pain mate! Hope it will be fairly easy to touch up
Sent from my Nokia 3310
Giddy on Mon Jan 29, 2024 8:27 pm, edited 1 time in total.
OxCaddy
Posts: 35 Joined: Thu Jan 25, 2024 12:58 pm
Post
by OxCaddy » Sat Jan 27, 2024 6:48 pm
Well I’ve spent the day changing injectors for the van to still run like rubbish
Post
by the swan fiend » Sat Jan 27, 2024 7:16 pm
It’s gonna need to go into the body shop mate. I’m hoping they can do a localised repair rather than respray the whole bumper
Poffe
Post
by Poffe » Mon Jan 29, 2024 11:44 am
Fitted a windscreen board yesterday. Job went surprisingly smooth.
Posts: 2302 Joined: Sun Apr 26, 2015 1:41 pm
Post
by petrev » Mon Jan 29, 2024 6:03 pm
I would be crying
Such a lovely van
Posts: 1746 Joined: Sat Nov 02, 2019 9:51 am
Post
by gazza31112 » Mon Jan 29, 2024 6:14 pm
Think it's time to learn how to plastic weld! Have to try and cut and fill in the wrap as well because there's no way I'm paying to get the whole bumper rewrapped, as it looks like I'll have to get the trim resprayed.
Gutted
