Engine not fully heating up
Re: Engine not fully heating up
The gauge is controlled by a coolant temp sensor that is sat in the water jacket. The thermostats are there to maintain a constant temperature one or both failed/failing can cause heating issues .
- NZDubNurd
Have a look to see if you have the DSG stat too - there is a skoda forum article somewhere. It's inline, in a hose and shouldn't be confused for a one way valve some cars have. They look similar, but the stat one has a metal clip in it.
Either one not stopping the flow properly, means coolant can go to the radiator, when it should be circulating inside the block only (mostly).
- DeanWhit
Finally sorted. It was the DSG stat.
