Hi all!
I have a 2017 with a window on the sliding door. I'd like to replace it with a door without a window. It looks like doors from earlier models are the same. Are they?
-HJ
Are all sliding doors the same through the years?
Re: Are all sliding doors the same through the years?
Hi, yes any caddy mk3 or 4 door should fit. Just bear in mind that the SWB door has a cut out for the rear wheel arch whereas the maxi doors do not.
Maxi and swb doors are slightly different aswell.
- Nicklouse
Maxi and sub are totally different. Keep to the same wheelbase and you will be fine.
