Spiderman
Post by Spiderman »
Cleaned my new van, changed the battery and coded it in, enabled digital speedo and set lane change indicators to 5 flashes instead of three. Then put some alloys on.
@ Spiderman, how old is your van? I never had to code in my new battery when I fitted one to my 2011 van.
Does yours have start stop or anything?
At least I don’t think it needed coding, I just put it on and it all worked as normal.
thecolourpurple
Post by thecolourpurple »
@swanfiend . Hey Pete sorry to highjack your post but battery does need coding with stop/start
Sent from my SM-S908B using Tapatalk
Ahh ok, that makes sense. My ancient van doesn’t have that
Cheers mate
Poffe
Post by Poffe »
My understanding is that in order to optimze charging cycle and battery life time you should code your new battery in. I dont think it has anything to do with start and stop function.
Anyway, here is a youtube "how to" from Ross-Tech
https://www.youtube.com/watch?v=IJAScg6JrYI
thecolourpurple
Every day, a school day, guys
BagleyCJX
Post by BagleyCJX »
Colour coding mirrors currently
Poffe
Post by Poffe »
BagleyCJX wrote: Wed Apr 10, 2024 1:38 pm Colour coding mirrors currently
That is an entirely different type of coding :D
Currently not available in VCDS
thecolourpurple
BagleyCJX
Post by BagleyCJX »
Poffe wrote: Wed Apr 10, 2024 4:58 pm That is an entirely different type of coding :D
:mrgreen: :mrgreen: :mrgreen:
Scimitar
Post by Scimitar »
Today I started to convert my wheelchair converted maxi life back to a standard 7 seater.. Ramp is off and have plan to rebuild the floor etc back to level.
So far so good
raitis
Post by raitis »
Changed my front passenger side wing which had horrible rust issues because of a previous repair (the arch had been welded from the inside) to a better used one. Now I can't get my front bumper to slot into the bumper bracket :oops:
mac12
Post by mac12 »
Had to top up my coolant, I suspect a small leak somewhere. Not much, just a couple of dL since I last filled before christmas. Any usual culprits I should check? Don't see any puddles anywhere, no white smoke in the exhaust nor residue in the oil so I don't suspect it's the head gasket. Water pump, maybe? I'm at 140km / 86k miles.
bert682
Post by bert682 »
mac12 wrote: Mon Apr 15, 2024 9:55 am Had to top up my coolant, I suspect a small leak somewhere. Not much, just a couple of dL since I last filled before christmas. Any usual culprits I should check? Don't see any puddles anywhere, no white smoke in the exhaust nor residue in the oil so I don't suspect it's the head gasket. Water pump, maybe? I'm at 140km / 86k miles.
Had something very similar, turned out that the plastic inside the oil filter housing had perished. Replaced this and no leaks since.
