Posts: 1746 Joined: Sat Nov 02, 2019 9:51 am
Post
by gazza31112 » Sat Aug 23, 2025 4:48 pm
My first prototype of a new style led grill
Sent from my Pixel 9 Pro XL using Tapatalk
Posts: 2302 Joined: Sun Apr 26, 2015 1:41 pm
Post
by petrev » Sat Aug 23, 2025 5:03 pm
Ah, yes.
More crazy, mad, fun inventions from Gazza
Nice one
Posts: 1097 Joined: Sat Mar 18, 2023 5:28 am
Post
by stu_b » Sat Aug 23, 2025 11:24 pm
@Petrev that's mad, full on but I guess good safety, esp at night if broken down etc
@gazza31112 why do u make these things look so simple yet to the average guy virtually impossible !! Looking forward to the end result n write up
mirogo
Posts: 27 Joined: Thu Dec 14, 2023 4:06 pm
Post
by mirogo » Tue Aug 26, 2025 11:20 pm
gazza31112 wrote: ↑ Sat Aug 23, 2025 4:48 pm
Hi, is it possible to remove this grill from the starline bumper as well? MK4 Many thanks
Post
by gazza31112 » Wed Aug 27, 2025 5:01 pm
@mirogo hi mate, I believe the startline ones are moulded into the bumper...
Post
by gazza31112 » Wed Aug 27, 2025 5:13 pm
Attempted a doorcard retrim....
caddy25
Posts: 32 Joined: Sat Aug 09, 2025 5:56 pm
Post
by caddy25 » Wed Aug 27, 2025 7:30 pm
well today was productive started out like this back door was fully covered in carpet
so time to rip it all off and do it properly
all glue cleaned off took ages but came up very well then re covered the rear panel instead and re fitted it back onto the door
and the other door done aswell
''cross threaded is nature's loctite''
Andrew5
Posts: 122 Joined: Sun Jun 28, 2015 10:30 pm
Post
by Andrew5 » Thu Aug 28, 2025 7:30 am
@caddy25 what did you use to remove the glue from the paintwork thanks
caddy25
Post
by caddy25 » Thu Aug 28, 2025 7:43 pm
Andrew5 wrote: ↑ Thu Aug 28, 2025 7:30 am
holts tar and glue remover i sprayed that on first let it dwell for a bit then used and old card to scrap the heavy stuff off did this about 3 times on both doors then used a microfiber cloth and some petrol to get the remaining glue off
Post
by gazza31112 » Thu Aug 28, 2025 8:50 pm
I was also going to ask this, done a bloody good job! Iv been trying with an adhesive remover, it's very slow going!
Andrew5
Post
by Andrew5 » Thu Aug 28, 2025 9:11 pm
Niceone cheers I managed to get some overspray of the glue when doing my carpets
caddy25
Post
by caddy25 » Thu Aug 28, 2025 9:16 pm
gazza31112 wrote: ↑ Thu Aug 28, 2025 8:50 pm
the trick is too spray a heavy coat on and leave it soak in to the glue its tedious but it does work ive found the holts tar and glue stuff is good the more watery tar and glue remover tend to dry way to fast
caddy25
Post
by caddy25 » Thu Aug 28, 2025 9:20 pm
Andrew5 wrote: ↑ Thu Aug 28, 2025 9:11 pm
should work a treat for that
caddy’lack
Posts: 12 Joined: Tue Aug 26, 2025 6:16 pm
Post
by caddy’lack » Thu Aug 28, 2025 9:45 pm
Used Saphire Renomat and Renovation cream to bring back black color to the steering wheel
Post
by gazza31112 » Fri Aug 29, 2025 4:24 pm
Finally got the correct led controller to finish the headliner
