Jack-uzii
Post by Jack-uzii »
Today i found out that my phone charger is slowly draining the life from the caddy… so after swearing at it i removed it
STP
Post by STP »
I had a glow plug fail, No. 2. Bought a set of Bosch plugs and set to it. 1, 2 and 3 came out easy. No 4 was a complete tart. It fought all the way and had weird dings in every thread at regular intervals once it came out. Looked like it had been gripped with pliers before being fitted. Probably original plugs from new.
No idea how No. 4 came to have damaged threads but eventually I got it out and fitted the new set. All good now.
What next!
This year it's had full new front brakes, inc. calipers, pads and discs, new lower arms, bushes and ball joints, new gear shift, new stereo, new night breaker headlight bulbs, new led drl bulbs, new number plate bulbs, an engine cover, new AGM battery...
davoc220
Post by davoc220 »
Fitted my heated fan washers and ran the wiring through the bonnet, got it tied up behind the expansion tank for now til I get it ran round the van, there’s only so much il do on nightshift
son of eevil
Post by son of eevil »
Caddy Rob wrote: Sat Oct 11, 2025 10:01 pm Today I took the shocks, steering knuckles and driveshafts of the touran, had to take them off together as I couldn’t undo the driveshaft bolts😡.
Only got one side off of the caddy, what a f#€king ball ache. The three bolts under wiper motor are a bitch to get at!!
Had to split the bolt on the drop link to get it off.
Will have a go at other one in the morning and get the touran ones on.
After that think all the mechanical bits are done💪🏼 and I’ll be moving on to the electrics!
Man, save yourself the knuckle busting and just take off the two screws holding the wiper assembly in place.
Caddy Rob
Post by Caddy Rob »
🤣 yer my knuckles are mashed, did take wiper etc off the touran which did make it much easier but thought I’d manage without doing it on the caddy.
Will take them off this time though! Gotta come back off cos driveshafts don’t fit 😡
Caddy Rob
Post by Caddy Rob »
Started my caddy for first time after doing a sdi>tdi swap.
Now to work out why;
the radiator fans stay on
What size driveshafts I need to get
Why the shudder valve is active constantly
How to turn off the brake pad indicator
And why temp gauge doesn’t work?
Got a few lights up on the dash mainly for abs steering angle and door electrics.
Oh and stereo is in safe mode.
So still a way to go before I can drive it again!
Flog_TSC
Post by Flog_TSC »
son of eevil wrote: Big difference then?
Any change to the fuel efficiency?
If I’m just mooching around fuel seems to go further
Flog_TSC
Post by Flog_TSC »
Jack-uzii wrote:Today i removed the bulkhead, attempted to fit carplay but ultimately was not impressed with the quality of the screen so returned it (any recommendations for a mk3 caddy?) then sat in the back and enjoyed the fact i can chill in my van
I have ended up buying 2 different cheap Chinese crap ones and I’m not impressed with either of them what have u been looking at ?
SainzFab
Post by SainzFab »
Ive managed to get hold of another MK3 van thats got some engine problems buit is better specced than mine for next to nothing, so Ive started swapping parts over.
Swapped the plain sun visors to ones with mirrors and sliding covers
Swapped the interior light to the one with maplights, but it doesnt work with the door so needs investigating.
C Chis
Post by C Chis »
Fabricated a couple of blanking plates, the strengthening section for the tailgate bracket and tried out my novice spray painting skills on the blanks and strut repair brackets
Flog_TSC
Post by Flog_TSC »
Fitted my new wheels :)
davoc220
Post by davoc220 »
Ordered a set of wheels, Audi TTRS Concave alloys, 19” just need to see what tyres il put on them when they arrive
mirogo
Post by mirogo »
painted my bulkhead from scrapyard
Looking good 👍
Happy Christmas everyone 🎁⛄🎄
Flog_TSC
Post by Flog_TSC »
I drove to the canal then smashed 24 miles on my bike and then wonders why I had no boost in the van and seems to have sorted it self out but that’s a problem for another day
