I have a 2010 caddy maxi the wipers aren't working but I've tested both the wiper motor and the washer pump both got power going to then and working and there's also power going to the relay thing does anyone know anything else that could be cause this I've also replaced the stalk so im out of ideas any systems they go through or anything else that could be causing it would be much appreciated
Sent from my SM-S928B using Tapatalk
Wipers and wiper pump not working
C-mills24
STP
Re: Wipers and wiper pump not working
The wiper stalk sends a signal to the cecm (central electrics module) under the dash, above the fusebox and it then sends a command to the wiper motor and washer pump, it's not a direct connection like on old school cars. It's canbus communication - the stalk triggers a canbus message with a particular ID and that is how it knows you want the wipers on. Different positions trigger different CAN message IDs.
If you have a diagnostic tool, you can command them to run under "output tests", if they do, then the message from the stalk to the cecm is not getting seen, if they don't, then the cecm outputs are possibly faulty.
Trace the cable from the stalk to the steering column module and the wiring from there to the cecm under the dash (drivers side in UK RHD) then see if there's corrosion on plugs, a broken or chafed wire, etc.
Bidirectional scan tool like vcds, or TopDon or something is required to be sure which end is at fault mate.
One more thing, have you had the steering wheel off by any chance before this happened?
Gary.8
Have you checked the bonnet sensor switch .....
Dislexicdonkey
Yep check the bonnet sensor, if it’s not closed fully you’ll get nothing from wipers or jets
- Baldspeed Racing
Ive got the same issue with mine, ordered a secondhand wiper stalk set up from ebay as checked all the fuses and tried a pump swap on Friday
@baldspeed on Insta
