Caddy bass van
XmaxxCaddy
Re: Caddy bass van
Post by XmaxxCaddy »
Basshead6400 wrote: Tue Jun 10, 2025 1:02 pm
Thank u for the explanation and pics !
That gave me some good ideas for when i get that far with the build.
Talking about inspection,,,, What about your suspension setup ? Did you go the "Air suspension" route or how did you work your way around the weight of the build ?
I bought an lowering kit for mine, but i´ve already lifted it almost all the way again, and i havent even mounted any of the equipment yet, only the enclosure.... :/
Btw, very jealous of the birch wood you are using. You must be a secret millionare with the current birchwood prices :D
Feel free to copy anything you here :D this kind of information feels so hard to come by nowadays because everything is just facebook posts or private groups.
About inspection, i have done a modification inspection where the weight of the van was increased to 1950kg. Last time was done with almost stock suspension setup, rear has an additional leaf spring that is used on taxis, but it isn't nearly enough with this one.
I got some BC Racing coilovers that i've just recently installed, well just the front but i'm doing the back in a week. I'm planning to put some heavy duty leaf springs but most likely I have to go the custom route with them.
Birch prices are quite low here in finland, just talked with the guy who is supplying those lithium batteries from Norway. He sends birch to norway because it is literally just 1/3 of the price in here and they send him the battery modules as exchange.
Mcaddy wrote: Sun Jun 15, 2025 2:29 am This is awesome, fave tune to pump through it?
Hmm, I got some favourites; Stereo love, but that is with the bass turned low, Suicideboys - For the last time, Kevin Gates - Paper chasers and then for some rebassed action: Maximum Bass - Drop top (25hz) and Got160's version of Madonna - Hung Up (18-29hz). 18hz is pretty much the lowest this thing will go and it is always breaking my doors, but i still love that wind :lol:
Caddy is now back in action and has done 2 shows already this summer. There is some problems with the amplifiers so i only get 1500w (per amp) out of them before they drop into protection mode. I'm running them on 0,5 ohms but it seems like they can't handle that in this enclosure. Im putting some applications for invite only shows: Power truck and HTS, hopefully they like it as much as in here :D
A lot was done in last months: Door pods were painted and installed, amp racks were redone, some LEDs were installed, new wheels, front lowered, new front port for the enclosure and lots of smaller things i just don't remember. Now im fixing some damages and installing rest of the batteries.
Doors: Painted with glossy black, then mixed the clear coat with some purple flakes. I think they turned out great for a first time flake painting.
Then spend like a week trying to make the wiring look good, some parts will be redone when i get the full battery pack.
Here's some pics from the shows and with the new wheels, they are 2-piece Artec wheels, 17x9 et -47, i'm running them with a 5mm spacers. 225/45r17
desertpool
Re: Caddy bass van
Post by desertpool »
Nice work mate, looks spot on!
2017 VW Caddy Mk4 C20 Startline – 2.0 TDI | 150k miles
PJD
Re: Caddy bass van
Post by PJD »
Incredible build and something differentb and done to such a high standard.
Can't imagine being in it with the music cranked up.
XmaxxCaddy
Re: Caddy bass van
Hello again! And thanks for the comments :D
Summer is now over so now it’s time to fix everything that broke :mrgreen:
Right side door is properly f*cked :D Most likely have to replace the whole door and paint it.
Broke total of 3 subs, 2 of them are already reconed and last 1 only has a broken surround so maybe I’ll try to fix that.
Went to the final round on Propperdroppers, my score was 160,9 db with ''only'' 7 subs.
40hz=160,06 33hz=160,18 25hz=161,62 and 20hz=161,01. Still decent but i'm just thinking what if I had all 8 of them...
HTS 2025 was a blast, went there with a another crazy caddy from finland!
We were invited to AIGroups department, those guys sure know how to party :D
XmaxxCaddy
Re: Caddy bass van
Hi! Some progress on the rebuild:
Wheels were in a quite bad shape so i started by polishing the lips. Made a diy polishing rig with an old subwoofer box and a wheel hub :lol:
Forgot to take a picture of the unholy contraption but oh well...
This was the starting point:
First they were water sanded starting with P1500 -> 2000 -> 3000. After that they were polished with medium polishing wheel, then with metal polish.
Turned out pretty good 8)
Cabin is mostly disassembled and subs are out, enclosure is getting painted and some port modifications:
Speaking of ports here is something you won't see everyday :lol:
I made a diy aeroport from an old sewage pipe. Old port was 10 inch and this new one 12 inch, couldn't get that from any shop so let's here is small tutorial how I made mine:
Starting point is to make a mould for the rounding (r), this was made by screwing old subwoofer cut outs together and then shaping it with an angle grinder with a milling disk, i think the one I used was P14. Then smooth it out with filler so the pipe slides easily.
Then is the messy part:
Get a metal pot slightly larger than the pipe, and then fill it to about 12 cm with oil, any oil is good, I think cooking oil is the best but i had some old hydraulic fluid so used that, also i didn't have any proper sized pots so I used an oil barrel :D Also some more controllable way of heating than a campfire would be preferred, but hey if it works what can I say :D
''Cook'' it about 5 minutes at 150°C, my thermometer only worked up to 105°C so i just winged it, this is not an exact sience :lol:
After that the plastic should be very soft and ready to be pressed. This takes a surprising amount of force so use a bottle or a scissor jack against a immovable object. I used my dads old truck and then some pallets to adjust the height.
This is how they turned out:
Some comparison pictures with the old ports, one of the ports started to split but luckily that doesn't matter because i have to cut that part anyway to fit the port.
Progress is slow but hopefully it is back in business by April.
XmaxxCaddy
Re: Caddy bass van
Hi, quick update on the rebuild:
4 battery banks here
4 more to go with upgraded copper bars
12 inch aeroport installed with some metal flake paint
Wheels are almost ready to be assembled
Bought the new subs, Ground zero Plutonium Xmax-II. Had the old version before and the were monsters but had some problems with the lower spider, new subs have 12 ich spiders so that problem should be fixed.
TimOk
Re: Caddy bass van
Post by TimOk »
Alot of hard work and time went into this. Great job!
