MK 5 SOS button
John M
MK 5 SOS button
Post by John M »
Had an update from VW for the van and now I have the dreaded "SOS call button restricted" VW dont seem to care tbf and the local main stealer just wants money. Anyone had this and is there a work around ? apparentley the software update makes a false flag that the reserve battery is dead, which it isnt and if it was its behind the dash im told.
DW2207
Re: MK 5 SOS button
Post by DW2207 »
Get the sos module scanned first and foremost john.
Had a fault in my now t6.1 transporter and it was a damaged gps module. Short to ground.
The sos system has quite a few parts to the system that are monitored.
Yes could be battery, yes could be software. But without proper diagnosis you will just be guessing.
Get obdeleven pro dongle and do the scanning yourself and hopefully repair without going down the dealership route, unless you have warranty.
Good luck
Sent from my SM-S921B using Tapatalk
John M
Re: MK 5 SOS button
Post by John M »
Im out of warrenty but i only have 20k on the clock, failure electronically is a bit of an issue with these vans.
DW2207
Re: MK 5 SOS button
Post by DW2207 »
John, if you are near Essex, i can scan your van free of charge to see whats what with the module mate.
John M
Re: MK 5 SOS button
Post by John M »
Ah mate that would be great but im about 350 miles north of you thanks tho.
