As per title, I pulled the complete cruise control stalks from a Touran 2009 along with clock spring and bottom module and replaced them all into my 2005 Caddy.
I noticed the caddy had an extra steering position module that the touran never had and google-foo says its because its part of the touran clock spring now. Also the steering module didnt have the pins to transfer the module anyways.
Anyhow, cruise seems to work in VCDS and I'm getting the signals from all the switches and clutch and brake pedal, but the van has a yellow steering wheel error now on the dash and I cannot get rid. Both through coding and various diagnostics.
Any ideas?
i THINK the van is expecting the sensor module to still be there and not via the clock spring, but thats just guesswork. I was hoping a matched set from the Touran would be compatible, but I'm missing something. Incorrect coding perhaps?
Perhaps as I still have the Caddy Clocks in and not the Touran ones yet ? Still waiting for a cable to arrive so I can get the Pin numbers and try a IMMO transfer.
Touran parts used...
1k0 959 653 C - Clockspring
1k0 823 248 CQ - Module
1k0 953 519 J - Right Wiper Stalk
1k0 953 513 G - Left Indicator Stalk
Retrofit Cruise and now steering sensor issue *FIXED*
Azzi
- C Chis
Re: Retrofit Cruise and now steering sensor issue
The SWCM (from the Touran doesn’t have/support the steering angle sensor that was plugged into your caddy’s SWCM as the steering angle sensor will be integral to the actual power steering on the subframe.
Check out the Rosstech website to find a suitable module https://wiki.ross-tech.com/wiki/index.p ... e_Versions
You’ll most likely need one that supports the steering wheel angle sensor. Find you original one on the list and find a midline or highline one the same software level and LIN version that supports the steering angle sensor.
The Rosstech site also gives the right info for coding in the cruise control including the code to enter to enable cruise control once you’ve coded the module in.
Also… as your van is pre 2006 you’ll need to check your SWCM has the diagnostic wire fitted. Check the black plug on the SWCM, T20, pin 13. If this is missing you’ll need to run a wire from pin T20/13 to your ECU T94/20. The wire if installed should be blue/white.
Azzi
Thanks Chris, I kind of figured out most of that through brute force and ignorance.
I had version E of the Module and was trying to replace it with a CQ, which your right, it needed the other method of reading the steering angle. so I've managed to grab a version F for £20, keeping it in the same family and date range, but will have the Cruise and Midline support on the dash.
What does LIN mean or do? Mine never had it and neither will the new one. it sounds like a Network like CAN.
As for the Diagnostic wire, I havn't checked, but as I was getting feedback in VCDS from the stalks and buttons, I assume I have.
Guess I'll soon see once I get the yellow wheel error sorted and see if cruise works or not.
Would having LowLine clocks still in stop it working? I've not fitted the Midline Touran ones in yet, as I need a method of extracting the keys and firmware from the clusters first.
- C Chis
Hi,
LIN, can’t remember, I’ll have it somewhere
The buttons communicate via the module and the Canbus, the wire is direct to the ECU. VCDS will only check/confirm the cruise buttons are working, the wires separate.
Clocks shouldn’t affect cruise. I started with low line clocks and retrofitted cruise control.
Azzi
Still got an error on the Steering Assist and I just can not get it to calibrate.
I can go into group 060 and 1st box says OK, so sensor is being accepted.
Heres a Scan log.
Wednesday,20,May,2026,00:55:54:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
VCDS Version 24.7.0.0
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WV1ZZZ2KZ5X093767 License Plate: TEST 2
Mileage: 192470km-119595mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZ5X093767 Mileage: 192470km-119595miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 DM HW: 028 101 188 2
Component: R4 1,9L EDC G000SG 9929
Revision: 12345678 Serial number: VWZ7Z0E1856005
Coding: 0050031
Shop #: WSC 00066 001 57865
VCID: 71E960C368A9131E3C-8025
VINID: 9E606AAAA09BA85A002431C61CE059ADBB
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.clb
Part No: 2K0 907 379 A
Component: ASR FRONT MK70 0105
Coding: 0017106
Shop #: WSC 35110 377 00162
VCID: 3169A0C3A829531E7C-8065
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001644650
Coding: 00884F020004100000000000000000000008FB075C
Shop #: WSC 35110 377 08192
VCID: 397998E370599B5EC4-806D
Subsystem 1 - Part No: 2K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW357 012 0402
Coding: 00065493
Shop #: WSC 35110
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD068VCN
Coding: 0012345
VCID: 7DF14CF324F1677EA8-8029
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenks ulenmodul 021 0050
Coding: 0000042
Shop #: WSC 06314 000 00000
VCID: 356194D35C417F3E20-8061
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 2K0 920 941 C
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0016403
Shop #: WSC 80093 222 69422
VCID: 295948A380F92BDEB4-807D
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 021208F1001960
Coding: E9801F02000202008003
Shop #: WSC 01324 785 00200
VCID: 377D9EDB464D8D2E32-8063
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0716
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0160
Coding: 0000000
VCID: 76E353DF01C73426E9-8023
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
2 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 2440 km
Temperature: 18.0 C
Voltage: 14.10 V
Voltage: 13.90 V
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 008A04087F2D84040858010010C0
Shop #: WSC 00527 210 92213
VCID: 79F958E330D95B5E84-802D
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: 75E154D31CC13F3EE0-8021
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 00000000 Serial number: VWZ1Z2K8242413
Coding: 0100020001
Shop #: WSC 00028 028 00001
VCID: 65C104936C61CFBE50-8031
End-------------------------(Elapsed Time: 01:45)--------------------------
Heres a Scan log.
www.Ross-Tech.com
Coding: 0050031
Coding: 0017106
Coding: 00065493
Shop #: WSC 35110
Coding: 0012345
Coding: 0000042
Coding: 0016403
Coding: 0000000
2 Faults Found:
Freeze Frame:
Mileage: 2440 km
Temperature: 18.0 C
Voltage: 14.10 V
Voltage: 13.90 V
Freeze Frame:
Component: KSG 0401
Coding: 0000000
Coding: 0100020001
Azzi
****FIXED****
Anyone having issues with the G85 Sensor not initialising, heres the method I used to finally get it working after a good fortnight of messing around on and off.
After a change of Steering module and a battery disconnect, my errors were.
2 Faults Found:
This is the order I did things to get back working again.
Steering Wheel to Centre
VCDS / VAG-COM
Reset DTC to clear any Cache first, fine if errors come back.
44 - Steering Assist Module
11 - Coding II
Enter 40168 - <Do It> (to unlock Steering Controller)
04 - Basic Settings
Group 60 - <GO> This should populate the 4 boxes if you unlocked the controller correctly.
Click <ON/OFF/Next button> at top right of screen.
2nd box shows 0.0 and does not change when you turn the wheel.
Take a small drive, keeping the steering fairly straight. it doesn't need far, It was only about 20 meters for me.
2nd box will now start showing a degree angle that alters with the turning the steering.
Stop car, keep steering centred.
Turn wheel completely to the right and hold against the stop for 5 seconds
Turn wheen to the left and hold against that stop for another 5 seconds.
Turn wheel back to centre (you can confirm on that 2nd box that wheel is centred, has to be within a couple of degree +/- of centre.
The yellow Steering wheel light on dash will have gone.
Reset DTC and re scan, the G85 will be initialised and working and the errors should not reappear.
Thank feck for that !
2 Faults Found:
VCDS / VAG-COM
11 - Coding II
04 - Basic Settings
