Right I been thinking today as Ive been lazy and had time to think of what bits i would change on my caddy.
The light up in the bulkhead, can this one be swapped for one like out of the MK5 R32? So it has the down light bit?
How easy is it to remove the centre console around the stereo as i fancy wrapping that?
Is it easy enough to remove the number plate light trim on the rear to wrap that to? Is it a case of undoing the panel and finding some bolts/nuts to undo?
Has anyone changed there headlight bulbs to say night breakers or anything like that to get rid of the yellow dull ting to them? Sorry I'm used to hids
I think thats it for now but im sure i will think of something else at a later stage
Few questions....
Few questions....
PodgeyPerfections
Re: Few questions....
How easy is it to remove the centre console :- pulls straight off
The light up in the bulkhead:- w8 passat light almost straight swap lots of info on here
bulbs change no bother
- tommyzooom
I put 4 nightbreakers in SWMBO Kuga, and they made a good difference, I might get a set for the caddy
